Setting the Time
I suspect I am being thick but there are two options for setting the time either Manual or GPS.
GPS is clearly more accurate but when I use this setting, using the time zone London GMT, the time reads one hour ahead. i.e. 0800 reads 0900.
Has anyone else had this problem?
It's a bug. The setting needs to be changed to 'Europe' via VCDS for the GPS clock to work correctly.
Is there not a tick box for Summer time ( think thats what its called ) in the setup, remove or add the tick and it should dshow the correct time. this is used to add/remove the the extra hour when the clocks alter
Yes but it won't allow you to put a tick in the box. In any case we are on GMT now until the clocks change.
