Throttle pedal bottom 'notch / click"
I have noticed when at full throttle if I press a little harder there's a 'notch/click' and the pedal goes another half inch or so.....
Is this just for kick down on DSG cars or does it serve any purpose on the manual gearbox cars ?
Found a post about it in the OCTY 3 section too..
http://www.briskoda.net/forums/topic/295371-throttle-pedal-bottom-notch/
In Eco mode, full pedal before the notch is mapped to about 75% throttle; you only get 100% in kickdown, it gives a nice boost.  In Normal and Sport, full pedal is 100% throttle so the kickdown has no effect.
thanks for confirming.
  • Administrators
I noted this on the launch cars...
I was told I was imagining it and none of the other reviewers I mentioned it to seemed to care much either.
Thank you for clearing it up so that I'm not mad :) Quite how no-one else discovered it on empty Scottish a/b roads I'll never fathom out though.
You must've been the only one who tried Eco mode!  If only kickdown in Sport would give 125% :D
On other brands kickdown also overrides speed limiter/cruise control (with manual gearbox). Not sure if that's also true on Skoda.
Def the notch click on mine.... When pressed nose bleeds usually follow ...
This^
I can confirm after a drive in eco mode if you floor it to the stop point you hit a end of range in power and then if you push through the notch the engine picks up a bit more ..
Makes no difference in sport mode.
Got mine in Eco drive mode in Individual setting for drive only.
  • Administrators
It was more no one else felt it. They were all diesels so maybe professional journalists just don't go there :P
