CarPlay Audible
Hi,
Anyone using Audible app successfully through CarPlay?
When I try I just get it sat on the "Opening you library".
If I start the book on the app on the phone however I can pause or play via the Now Playing applet.
Cheers,
Lee.
It's really buggy, if you press the home screen button then press audible again it will show the library, I have to do this for each page. I'm sure it'll get sorted at some point.
Double post sorry.
Edited by nicowalker85
I've had no problem playing Audible through Apple Carplay. Spotify also works well.
The only problem I have had is that sometimes when a traffic announcement breaks in then it is reluctant to return to Audible.
However I then hold down the voice command button and say "play audible" and Audible returns.
Had same issue. Learnt to start audible on phone after unlocking the phone screen and then works fine from the car . However have intermittent issue with lost connection on car play and need to unplug and plug back in the sub cable to kick it off again, usually lasts about45 mins and then every five mins or something. Was getting worse and finally gave up yesterday so have switched to simply bluetoothing the iPhone .
