Hey guys and gals,
Having a few misfiring issues, this is due to the rocker cover gasket leaking oil onto the plugs 3 & 4, No. 3 was gunked up really bad and as a result burnt coil pack in the process. I think thats why I had some smoking issues coming out of exhaust. Anyway I had bought new plugs and coils from tps and still the engine missing like mad. Sounds more a of knocking noise now. Spark plug No.3 seems to be missing some parts and I think its still in the piston chamber, could such a small piece damage said piston?
The car is a VRS MKII pre-fl 2006
Here is the VCDS scan:-
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
www.Ross-Tech.com
Tuesday,26,April,2016,12:53:42:49176
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBEF21Z468069605   Mileage: 238650km-148290miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1Z0 907 115 A    HW: 1Z0 907 115
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H10---    Serial number: SKZ7Z0E3299505
   Coding: 0203000318070060
   Shop #: WSC 66565 257 00032
   VCID: 336559EE52F570A6B3-8066
10 Faults Found:
012599 - Intake Manifold Runner Control (I did a basic reset with vcds, still coming up as an error)
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 237458 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:26:01
             Freeze Frame:
                    RPM: 756 /min
                    Load: 17.6 %
                    Speed: 0.0 km/h
                    Temperature: 85.0°C
                    Temperature: 53.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 237458 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:26:01
             Freeze Frame:
                    RPM: 756 /min
                    Load: 17.6 %
                    Speed: 0.0 km/h
                    Temperature: 85.0°C
                    Temperature: 53.0°C
                    Voltage: 13.843 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 237729 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:57:29
             Freeze Frame:
                    RPM: 759 /min
                    Load: 15.3 %
                    Speed: 0.0 km/h
                    Temperature: 81.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.097 V
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 238629 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:08:23
             Freeze Frame:
                    RPM: 3899 /min
                    Load: 54.1 %
                    Speed: 158.0 km/h
                    Temperature: 66.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.224 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected - MIL ON
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 238629 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:08:23
             Freeze Frame:
                    RPM: 3899 /min
                    Load: 54.1 %
                    Speed: 158.0 km/h
                    Temperature: 66.0°C
                    Temperature: 18.0°C
                    Voltage: 14.224 V
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 238638 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:29:37
             Freeze Frame:
                    RPM: 2870 /min
                    Load: 25.5 %
                    Speed: 57.0 km/h
                    Temperature: 82.0°C
                    Temperature: 23.0°C
                    Voltage: 14.097 V
004964 - Cylinder 4 Ignition Circuit
               P1364 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 238656 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:32:38
             Freeze Frame:
                    RPM: 250 /min
                    Load: 61.2 %
                    Speed: 0.0 km/h
                    Temperature: 11.0°C
                    Temperature: 11.0°C
                    Voltage: 10.795 V
004952 - Cylinder 2 Ignition Circuit
               P1358 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 238656 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:32:38
             Freeze Frame:
                    RPM: 250 /min
                    Load: 61.2 %
                    Speed: 0.0 km/h
                    Temperature: 11.0°C
                    Temperature: 11.0°C
                    Voltage: 10.795 V
004961 - Cylinder 3 Ignition Circuit
               P1361 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 238656 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:32:43
             Freeze Frame:
                    RPM: 254 /min
                    Load: 60.8 %
                    Speed: 0.0 km/h
                    Temperature: 11.0°C
                    Temperature: 11.0°C
                    Voltage: 10.668 V
004949 - Cylinder 1 Ignition Circuit
               P1355 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 238656 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:32:45
             Freeze Frame:
                    RPM: 255 /min
                    Load: 60.8 %
                    Speed: 0.0 km/h
                    Temperature: 11.0°C
                    Temperature: 11.0°C
                    Voltage: 10.795 V
Readiness: 0000 0000
Can you take a photo of the plug?
Anything in the chamber will be terminal
Time to get out the compression tester I think
Piston 1
Piston 2
Piston 3
Piston 4
Can you get an endoscope and look inside the chamber? Could the injector have been damaged? Otherwise might be a strip down.
Got no access to endoscope. It's booked in with vw specialist next week. I'll keep you guys posted on what happens.
Sent from my SM-G925F using Tapatalk
Good luck.
