Is lane assist programmable within vcds
Is this one of the options that is buried within vcds or is a vrs fitment only?
Standard on the Vrs and L & K.
Optional Extra on other Models,
Edited by Auric Goldfinger
So buried within vcds?
Standard on Scout too.
.............and the Scout.
Don't think so as a  Camera is required  ( I think )
The camera built into the rear view mirror unit?
I think that my VRS doesn´t have Lane Assist..
 Yes.
What else have you got that needs the camera? Can you definitely see the camera in there? Might be worth checking with your dealer if there is a camera there.
Does it show in the menus in your Bolero etc, and the maxidot display? If it does, and you can't enable it, the dealer should sort it free.
Was it included in Portuguese specification in 2014?
Camera is there well looks like one and I have Headlight assist so does the same camera function for lane assist?
If you are able to access it then I'm pretty sure you will turn it off in the same week :-)
In theory it's great but in practice it's just a bit to annoying....
Probably, I wouldn't expect there to be two cameras, not enough room.
Same week? That's six and a half days longer than I took.
I am starting to think if all of the available options to my car can be programmeed via vcds will my Gfv be higher.
Suddenly this bland elegance estate dsg has lane assist, cornering fogs etc. Surely a way to up ones final value?
