DSG Noise & Vibrations when chaning from 3 to 2 and 2-1 gear 57 Octavia 1.9
Hello everyone,
I am new here, just bought my first Octavia and fell in love instantly :D
This is my first automatic car so thought to ask you for your help - the dsg is a little bit noisy (gets louder but not a crunching noise) and a slight vibration can be felt when the car shifts down from 3 to 2 and 2-1 gear on D. It does not happen on other gears or when shifting up. It is 6 speed box.
Could you advise if this is normal or may require software update? Or is this a sign that something is wrong?
Thank you very much in advance,
Mike
Edited by mikeredhill
A vibration isn't normal no.
How many miles are on the car? And has it had the DSG oil and filter changed every 40k miles?
I'd say oil and filter change too.
The 6 speed is the wet clutch too, so if the oil hasn't been done, that could be causing issues there too.
Thank you guys. The car has 115 000 miles. The engine oil & filter has been changed last year, not sure if/when the DSG oil has been changed. I have booked the full service + DSG oil replacement with Skoda for end of August. I am not sure if I should call it vibration, but I can 'feel' when it is changing from 3-2 and 2-1 gear, cannot feel it with other gears.
Yes I can feel the car downshifting.
Just like with a manual gearbox if you shift down a gear and release the clutch you can feel this.
Unlike a traditional automatic gearbox the DSG has a direct drive due to the clutches and not through a torque converter so isn't quite as smooth.
If it's exceptionally jerky or harsh this can also be a sign of a worn DMF or engine mount.
Thank you, Phil. I am hoping this is normal then ;) Will see what Skoda tells me on the 30 August. Cheers
Thank you, Martin. Could you advise how expensive was to replace those 2 mounts please?
I agree with Phil it could also be the sign of an engine mount on its way out. I had very notchy downshifts from mine and ended up getting the 2 mounts changed in the subframe that attatch the gearbox to the engine. Now the downshift is much improved. My car is on 140k so yours isnt that far behind.
Thank you Martin. I will try with that ;)
  • 4 years later...
Hi, Mikeredhill have you found any solution for the issue? I have the same issue
Might be worth starting your own post buddy...
Mike hasn't visited the site for over a year...:thumbup:
