Minty the 1.8t Fantasy Green Fabia
30 minutes ago, Motoract said:
Please get the car dyno tested before you fit the injectors, I'm curious what power my mapping is making :-)
Will do.. I might be going to a rolling road day in May so will post results here :)
  • Replies 109
  • Views 20.8k
  • She survived her first track day!   Didn't do too badly to be fair, better than I expected. Brakes and diff next...     The 3 1.8t motors chasing the 32...
  • So I might have had a bit of a bargain on eBay for something for the future   Got hold of a set of 4 Siemens 630cc injectors for 1.8t with fuel rail and spacer kit for the grand total of £62
  • I've been away from home a lot recently due to starting a new job so not getting as much time as I want on this. Managed to get a few days sorted and heading in the right direction now.   Th
The loom is now completely out of the Ibiza.. Also managed to get the firewall out using a heat gun :D
The airbag has been removed from the steering wheel, and used the Ibiza's clocks' electronics with the Fabia dials to get the red back lighting. Also swapped the motor for the fuel gauge so hopefully it'll go in the right direction now as the Ibiza fuel dial is the "wrong" way round :)
Some pics as always;
Managed to get some free time last week and over the weekend;
A/C pump + pipes are in;
Firewall back in;
Next jobs are to swap steering rack and power steering pump over from the Ibiza. Can start on the wiring as well and the dash.
I have unfortunately got a broken wrist so will see how much I can do in the mean time.
You going to be in the market for a fmic next? ;)
Depends if you want some drive shafts as part payment? :D
What you got mate?
Full airtek hard pipe and FMIC. Forge TB pipe too. Also Forge oversize TIP. Possibly Forge 007 too. :tongueout:
All that for a couple of driveshafts :D
Pm me a price mate. I've got a 007 but none of the other stuff lol.
Weight successfully added :D
That's not been changed for a while;
Can start on the wiring now - finally!
Edited by AJ7788
Getting there..
From this;
to the current state;
Message us when you want this FMIC.. :tongueout:
  • 2 months later...
Been a while since the last update, just not had time unfortunately but as she is booked on to the 6th of Nov track day it's probably time to get on with it.
Would be so much easier if the engine runs :D
Steering rack off the Ibiza;
New tie rod ends fitted;
In the process of dropping the subframe for the ibiza rack to be fitted, also swapping the power steering pump.
Ordered a new a/c rad, ball joints etc. Also getting some goodies on Wednesday which should improve a few bits ;)
As it's peeing down today we got on with some of the other things needed - swapped the Ibiza climate control electronics etc into mk2 fabia a/c control case so it'll fit in the dash. Had to cut a bit of the centre console bit but it fits. This is only temp, will sort it properly later on;
Getting there but currently feels like one step forward and 5 backwards..
Solid Ibiza Cupra bushes along with powerflex wishbone;
Steering rack done and installed again;
New wishbones ordered and installed this evening;
And the next step ;) ;
Edited by AJ7788
Looks like someone's done a good job with the spray can :tongueout:
I didn't remove the brackets from the front, i'll remove them and send you them. :blush
Haha, I know right! :D That'll be perfect mate, wasn't sure if you needed them.. Was going to try and make my own but will save a lot of time if I have them :)
Ill sort them out this weekend as theyre on the front end in the shed. :D
She lives again! :D  getting there!
Woohoo :)
Did some more stuff this weekend - trying to get everything to fit currently. The Ibiza crash bar sits out further than the fabia one it seems - clears the pipework fine but pushes bumper out a bit too much so need to get that sorted, other than that doesn't look too bad;
Edited by AJ7788
None of them pics work for me..
Think it's the site that's having issues. Working fine for me now
It could also be down to the size of the photos as some of them are quite big.
Thanks - just using the link provided on imgur but will see if I can downscale.
Hopefully these will be ok for the track day.. at least until I can upgrade the brakes fully (Need bigger wheels etc etc);
Should be ok, just see how you get on with them. Be better than what was on it :)
