Warped discs.
seems like i got me some.not very happy.any one else had this on a fab vrs.no track days or owt daft like that.
Do you keep your foot on the brakes when you have come to a stop.
If so this cause much increased heat build up which in turn will cause warped discs or similar problems.
I've not noticed any problems on my octy, and don't know of similar problmes on a friends furby vRS.
no mate,always put on the hand brake when stopped at lights etc.
oh kinda bizzaro.
Well unless you are braking very hard then I would just say bad luck unless you have been through more than one lot.
I would guess a change them and see how it goes approach.
Almost certainly a build up of pad residue on the disc due to gentle braking, have a read of this
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
Then take the car out & use the brakes hard several times, Drive at 70 (more if you want) CHECK MIRROR, brake as hard as you can without kicking in the abs till nearly stopped then accelerate & repeat several time
As car been stood for any length of time _ forecourt etc?
Time for some 312's for you then. Be rude not to upgrade now!!
car not stood for any length of time so may try the hard braking approach,only 13,000 miles on her,no problems at service time,strange one eh?
a friend of mine, warped her breaks driving pritty fast and had to stop (in her octy vrs) warped the breakes, got them changed under warrenty:)
i must quiz the wife and see if shes been 'up to no good' wizzin about up rivington(local beauty spot with good roads for wizzin about on.)
Do you have standard pads? I've warped two sets of discs on a previous car when running ebc greenstuff pads wouldnt recommend them more trouble than there worth!
all brake parts are standard,many thanks for all the info y'all. i will try stomping on the brake pedal tomorrow, see how that goes, otherwise go for a warranty claim.
Is she a dogger? :D
oh dear,you know her then.
