OBD2 reader and my fabia vrs
I service my own vrs now its out of warrenty and i was just wondering if i need one of these to reset the service light and read any fault codes that occure.
http://www.autosvs.com/productsdetails/obdiican.asp
I also service a golf and ford ford focus and a Astra. All these cars are about 2 to 4 years old.
Or do you recommend i go down the laptop and connector route instead
no replies then????
If you've already got a laptop, then the Vag-Com lead from ebay is only £20 delivered from China.
You can then download the trial version of Vag-Com from the Ross Tech website.
good idea do you know if there is software out there that can be used for other makes of cars
I think you will find instructions on how to reset the service interval indicator in the owners handbook for the Fabia.
The Focus and Astra use a differant protocol to each other and the Fabia.
GM cars tend to use VPW - Variable Pulse Width Modulation
Ford use PWM - Pulse Width Modulation
Most others including VAG cars use ISO.
