Skoda Superb Estate 2ch dashcam install
Nice write up Roy.
Really good write up I might come back to this and give it a go once I get the car, Thursday.
One question did you consider taking the dealer stick off to get the camera close to the edge of the glass? That and a right angle connector would make it look much more discrete.
Hi Bud,
I did consider removing the dealer sticker, but it's one of those nasty ones that is a real pain to remove. I started peeling the corner and it was very brittle. I may still remove it and use some sticky stuff remover when i have more time.
Thoughtfully the dash cam kit comes with spare sticky pads for both front and back cameras so I should be able to reposition with minimal fuss.
I might buy a small right angle Mini-USB plug adapter at some point to tidy up the look. Good idea, didn't think of that.
Edited by RoyF280
1 hour ago, RoyF280 said:
Hi Bud,
Gentle warmth from a hair dryer will soften it and the backing glue. Makes it a bit easier to remove.
Edited by Devonshiredave
Update:
I wanted to try and tidy that rear camera cable a little.  The straight cable entry/exit looked a little clumsy so I started searching for a right angle connector of some sort.  Incredibly hard to find in the right size and orientation, but eventually found one by German company DeLock.  Only available via a couple of online retailers in Germany (with poor reviews) I ended up sourcing from Ebay.
I also wasn't happy with the tailgate trim sitting up over the cable and thought if I could file a small notch in it, it might sit flush once more.  Enter the adaptor and a £7 pack of needle files from Screwfix:
y4m7gAOiUEPYCNIM3pZ_kZkY8bhuxIAXMBjhaThN
A little bit of filing to create a small notch gave the following:
y4mdS-2Wn9gGL61R5gEXQr_23eaC52dSSikJ_dsC
Looks a little awkward like this with the tailgate up, but looks better when looking through the rear-view mirror now.
Before:
y4m6IOM_7hMuar9anExsItFEl26K1BMnmuInHC8S
After:
y4mEBYgY4dpMIxi7y10Xqidgpld-mtrxP3V1lXo7
The trim panel still isn't sitting flush and due to a metal lip underneath that the cable is running over, I'm not sure it will do.  However I might have another go with the files to take a bit more material out and see how it sits then.
  • 8 months later...
Thank you, this helped massively with the fitting of front and rear cameras today.
My only additions would be that my upper boot lining was screwed in as well, one bolt each side, but easy enough.
I used the nextbase hardwire kit which is 4m long and that's only just long enough to reach from the camera mounted in the middle of the screen to the fuse box via the passenger side rubber tube bit.  The drivers side is much emptier and easier to run cables through but you'd need at least another metre or 2 of cable.
I also haven't found the right fuse for camera2 yet.  Number 1 is plugged into fuse 35 but I ran out of time today to sort the second.
Andy
L&K 150 estate
Really helpful thank you. I’ll re read this when I come to install my Blackvue DR490L-2CH in my Sportline which will be arriving very soon with any luck.
You're welcome guys.  Glad it was of use :-)
Roy.
Hi Roy.
Are you still happy with your choice of QVIA AR790 WD – 2CH DASH CAMERA? I'm looking at buying it, and was wondering how you got on with it over your six months of use- any likes/dislikes or faults?
It's showing up as being over £329.99 to £469.99 if im on the right website. Was it worth that?
Thanks for the detailed post. Perfect.
Benny
Hi Benny,
Yes, on the whole very happy with it.  Images are clear and very good quality.  Thankfully I've not actually had the need to depend on any of them in anger yet, as I've had no accidents, near-misses or witnessed any others on the road, but it does give some comfort that such mishaps are going to be recorded for potential use.
The camera takes standard micro SD cards, but Lukas UK recommends quite expensive SD cards made by Delkin:  https://lukashd.co.uk/product/alphahatity/
They state normal cards don't fare well with the constant recording and overwriting and many fall short of the performance requirements of saving two lots of full HD video at the same time.  It sounds reasonable and I've certainly had no issues with the card supplied so far.  Video overwrites the card on a cycle, so when the card is full the camera deletes the oldest recordings and starts again. I guess you could go with cheaper cards and just replace them if they start to give errors, but I figured it's a bit like a smoke-detector; you want it working reliably, all the time, without fail for that one occasion you may need to call upon it.  So I'll stick with the expensive cards for the extra assurance they bring.
The camera is also set to format the card every 2 months, to keep it in good working order and performing at its best.  It prompts you first, so you can delay it if you want to, but if you press the required button and let it do its thing, it only takes about 20 to 30 secs anyway, so hardly an issue unless you're in an enormous rush to get going somewhere.
I've had a couple of occasions when on starting the car the camera has voiced it's usual startup sequence; "recording started" - followed by a little jingle, but then it pauses and reboots.  It doesn't happen very often and it always sorts itself out after about 4 retries.  I just figure its tidying up some video files and rebooting, but again not a big issue,
The night-vision feature doesn't seem to do a great deal in my experience so far, but that could be due to our street having a street-lamp immediately opposite and this could be causing the camera to record in day-mode, rather than night mode when it needs to.  I need to record some footage from being parked somewhere else to make sure this works properly, but just haven't got around to that yet.  I do have it set for constant recording whilst driving and motion-detection whilst parked.  (You can have "event" detection for driving rather than constant - where it records after detecting an impact and in this case it also records a number of seconds before the impact, so in-fact it's always recording a few seconds worth in this mode; just not always saving it)
It also has customisable voltage thresholds so even the car's parked and say it's raining (so the camera picks up a lot of constant movement) the camera will shutdown before it drains the car battery too low to cause an issue on the next engine start.
I'd recommend it, yes.
Roy
Thanks @RoyF280 for posting this how to, i used it yesterday to install a NextWave Duo HD dashcam.
Works a charm, I have blind spot (fuse 48) also and piggy backed this fuse , I tried fuse 38 which is the trailer but I was worried a permanent live might drain my battery despite claims of a limiter.
For anyone looking at the NextWave dashcam, it has a parking mode which will only switch on when it's G sensors are activated. You may miss the initial hit when parked, it will record as soon as it detects the hit.
This runs off NextWave battery and doesn't require a permanent live fuse connection.
Edited by Sw1
Well my camera is all Plummed in now. Oddly my parking mode isn’t working so need to suss that out.
i used the same empty empty fuse slots so thanks for sharing the guide.
Sussed it.
Ignition cable didn’t like 15 amp fuse, wanted 10 amp. Trial and error on my part. Didn’t think 5 amps would make a difference!
  • 3 months later...
Great guide @RoyF280, used it to install my front cam easily without any issues.
  • 3 months later...
Nice one @RoyF280. Just used your guide to help with installing my NextBase 512GW. Thanks for the detailed writeup.
Glad this is proving useful for people. B)
@RoyF280 I've got myself into a bit of a pickle when installing the rear cam. I struggled to get the cable around the headlining on the B pillar, but I was able to run it down to the bottom of the cloth area of the pillar, under the seatbelt, and back up the other side. Or so I thought... turns out that getting that panel back on is more tricky than it should be. I hadn't completely removed the panel, just popped away the bottom bit to squeeze the cable under. Any idea how I can go about putting it back? I subsequently removed the cable from under the pillar lining, just to make sure it wasn't in the way of any clips. Didn't help. I found some  reference about the Superb II that said you have to remove the Airbag logo clip and undo a screw. I tried, but couldn't prise it off easily, so assumed it's not removable. Any ideas?
Pics attached - passenger side showing my problem, and driver's side for reference.
I considered buying this manual, but I'm not entirely convinced it will go into detail about removing B-Pillar trim: https://www.emanualonline.com/product_info.php?products_id=16320{3}2
Hi,
First of all, I would remove the cable you've just run around the base of the seatbelt and try to reseat the b-pillar trim panel without it there.  You never know, you could have trapped the cable in between the panel and the bodywork somehow and it'll never go back...
If you can then get the panel to fit normally again, you'll at least have some sanity that you haven't damaged anything.
I found this Superb B pillar, which is from a 2009 model, and it does show the airbag cap, but no screw behind.  I'd still prise this out to see if there is a screw/bolt back there.
Also note no.9 on the picture.  It's not exactly clear where this clip goes from the diagram, but if you've dislodged it somehow, that could be what's stopping the panel from going back cleanly.  Best try to remove it completely, see if you can route the cable tidily with it removed, then try to refit when you've sussed out exactly how it should go back.
Sorry if this isn't particularly helpful, but it's what I'd do.  I didn't run the cable down and under as you have, I simply tucked it just inside the top edge of the b-pillar and it seemed to sit well out of sight.
Good luck!
Roy.
Thanks for the detailed answer @RoyF280. Yes, I did remove the cable, but it didn't help. I think something is slightly off-centre and not seating properly in its hole. I'll have a fiddle later and see if I can get it to go back.
@RoyF280 (and anyone else interested) - I just purchased the workshop manual for the Superb III and it is bloody fantastic. I bought it from: https://www.easymanuals.co.uk/product/skoda-superb-workshop-service-repair-manual/
For £14.99, I think it's worth any Superb owner having a copy. Every little detail about the car is covered, including removal and refitting of every nut, bolt, trim panel etc. It's the original workshop manual direct from Skoda. Example attached for the B-pillar. Not tried it yet, but I'm hopeful!
Looks great!
And looks like clip no.6 is probably your problem?
@RoyF280 done it! Inside the trim, there's a guide for the seat belt adjuster to slide up and down. It had popped out of its guide rails, which is all that was causing my problem. Ironically, the hardest part of all was removing the sodding Airbag logo. That thing wasn't budging. Ended up using a blunt knife to do it, as it was breaking my plastic pry tools. All good now! That manual is a godsend. Thanks for all your help.
