11836 - Cylinder Disabling & 6352 - Cylinder 3 Misfire
Hi all, had this straight after the MOT, literally within in 3 mins driving,  which I am hoping was an unlucky coincidence :
Fabia 1.2 TSI  Auto on a 12 plate.
2 Faults Found:
6352 - Cylinder 3
          P0303 00 [237] - Misfire Detected
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 53044 km
                    Date: 2017.04.18
                    Time: 10:51:45
          P130A 00 [109] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 12
                    Mileage: 53044 km
                    Date: 2017.04.18
                    Time: 10:51:46
All leads look in good condition and the car only has 33k on it. I am guessing it's either the coil pack, spark plugs or leads.
Will book it back in but presume by disabling the cylinder I am not going to kill the cat by limping the car home until it can be looked at? I gather it will also disable the injector stopping fuel going in?
Checking the coil pack I presume it is just the one which is for all four spark plugs?
Anyone have any luck with the primary cause?  I have heard there might be a new revision of HT leads out?
Cheers,
Chris
Edited by Plantman
Yea it disables fueling / coilpack , if compression is good will either be , spark plugs coils or faulty wiring :) or you could have a dodgy injector
Also the 1.2 tsi is distributor cap and ht leads job isn't it :)
Yea showing my age there ;)
Ah the good old days lol
Common fault those HT leads going faulty try changing the ht leads like put cylinder three in cylinder two and see if the missfire moves to cylinder two
One of the spark plugs (cylinder 3) was black so looks like a lead breakdown.  Since the leads and plugs had 30k on them they were changed and all is well again.
For info, plugs were £17 each and the leads were £63.
What Spark Plugs did you fit that cost you £17 each?
That is Skoda main dealer pricing. I paid a bit less.
