Roomster 5J 1.2 EPC light
Morning Folks
we have a 2007 Roomster 5J 1.2 with an EPC light problem.
Checked codes and it said throttle body and throttle pedal sensors. I checked the throttle body had it had a 2014 manufacture date. I replaced the MAF valve as one or twice when the EPC came on the brake pedal went hard.
I have since replaced the throttle body and the throttle pedal with secondhand parts.
When the throttle pedal was replaced there was a slight change in throttle response possibly due to different spring tension / resistance.
EPC light is still coming on.
What else can it be?
All suggestions greatly appreciated
Edited by eamonndelaney
clarity
Brake light switch/bulbs?
The problem went away shortly after the 2014 manufacture throttle body was replaced with a second hand one. Fitted a secondhand throttle pedal as well. Light came on twice since the parts were replaced but had been without issue for over a month. Had checked the bulb and have bought a new brake light switch as this was next to be eliminated.
I'd consider it "cured" at this point.
