ABS & TCS lights driving me mad!!
Please help.
ive had an ongoing issue with the ABS & TCS fault with my 2010 Octavia since April. It's being into my local garage numerous times and still the issue remains. (I'm not get charged for time just parts).    the VAGCOM error reports a near side front ABS fault.   So far it's had two new sensors, a new wiring loom on that side, a new hub in case the induction ring was knackered. An exchange ABS pump, that threw up another fault which was easily reset. Occasionally that threw up a communication error to the ABS pump.  So We,ve refitted the old pump.  When you first start the engine it gives a single tone and flashy up the error.
the car drives awfully as I can not accelerate passed 2500 revs and there is a distinct lack of power.
Before i I throw anymore money at parts can someone please suggest what is causing the issue. And where I go next.
If the hub and sensor have been replaced but you're still getting wheel sensor faults, it might be wiring.
I'd start with a VCDS autoscan and possibly live monitoring of the wheel rotation sensors.
