Removing wire from clock spring to replace
Finally got everything together to replace my clock spring. The only bit I'm struggling with now is how to remove the yellow wiring clip that goes from the steering wheel into the clock spring. I've wiggled it a bit but don't want to break it!
Actually scrap that I've just got it off... question is now is how do I get the new clock spring in...
Is the steering wheel off?
Yep steering wheel off and the housing surrounding indicators
It's just clipped on with plastic clips.
Three of these....
Thanks for that, one final (hopefully) question!
ive got the top half of the plastic housing off, but can't figure out how to get the bottom half off so I can plug the electrics at the bottom in
It's screwed on.
Bonus I've just found the part that tells me how to remove tge clock spring in my Haynes manual
Thank you for your help hoping I can get it fixed before going to work tommorow morning else it's the bus for me :(
No probs. Good luck :thumbup:
Bingo spring in steering wheel back on, and the airbag light is still on :(
  • Sponsor
I think airbag faults have to be actively cleared with VCDS or similar, even after the fault is fixed.
That's what I figured after reading more on the forum! However the ecu light that was on has vanished so that has to help!
Hopefully one final question I can get help with ... where's the best place to get replacement screws from.
Looks like someones had the steering wheel off before and lost half the screws for the plastic cover detailed above, and I've lost the bloody hex bolt (I was fixing it at 6am this morning!)
Steering wheel bolt is part number N90799101. You would have to get it from Skoda. There is a used one on ebay for an Octavia but it's just the same.
http://www.ebay.co.uk/itm/SKODA-OCTAVIA-2-0L-2001-STEERING-WHEEL-BOLT-/282370541964?hash=item41be98898c:g:hLEAAOSw3v5YrfWj
Or a Fabia listed one for a tenner http://www.ebay.co.uk/itm/Skoda-Fabia-MK1-Steering-Wheel-Fixing-Bolt-/292076828157?fits=Car+Make%3ASkoda|Model%3AFabia&hash=item440122b5fd:g:pTAAAOSwVctY5CLF
Column cowling screw size and part numbers are in my other post and should be available from Skoda.  It's quite possible to find screws of the same size elsewhere (ebay) though.
Edited by TMB
