Fabia 2010 ... Remove window switch
Hi ... new to forum ... have Fabia 1.2  2010 ... with electric windows on front windows only .... trying to take out front passenger side window switch to replace same with new one, but seems am not doing it properly, as not sure where the switch is clipped in door panel, and how to disengage same without taking out door card ... can somebody please let me know how to take out front passenger switch without taking out door card .... not sure if it is even possible without removing door card .... also some pic or vid explaining same will be quite helpful ... found one vid on youtube where front driver side switch is taken out, but am looking more for front passenger switch .... sorry .. just want to ensure I do it right and not damage something else with big repair bill while having a go at it ... thanks
the removal process is the same if im not mistaken. you take off the cover over the door grab handle (it just clips on, but its pretty tight.) then use a small screwdriver to push in and up on the front of the switch, then the back then it should be out
