Superb sportline 2017 boot trim
Hi,
ive got a superb sportline 2017, I've got the car over in Germany with the forces and because it's over here I have to have the left fog light on instead of the right, I know you need to wire it over from the right side, however me being non mechanical whatso ever how do I take the plastic boot trim off, looks tricky with the electric boot button etc,
any help would be much appreciated
cheers
steve
  • 7 months later...
I realise the OP has probably fixed this by now but thought I'd add to it in case anyone else comes across this post.
If this doesn't happen anyway when the lights switch over - not sure if it does or not.
It can be done in software adaptations using vcds/obdEleven - it is also possible to have them both enabled so it can be used anywhere.
How do you do this? can you post the procedure with VCDS?
There are some details here for Octavia - I believe Superb is the same. There are also some videos on youtube if you search
