Mirror dipping not working
Dave77
This will work inly if your car is Mk3 MQB platform
Enabling passenger mirror dip on selecting reverse
Tested on Elegance, vRS & SE
Controller 52 - Passenger Door
07 - Coding
Byte 4
Enable Bit 2
Enable Bit 3
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptation
(15)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt - change to active
This setting enables a menu item in Infotainment
(20)-Access control 2-Menuesteuerung Spiegelabsenkung - change to active
Remember, the mirror switch needs to have the passenger mirror selected for this to work, and the mirror only dips a fixed amount if you don't have memory seats
Edited by claudiu2s
4 hours ago, Paulius55 said:
You also need to tick the option box in the menu setup on the screen, under lights/mirrors or similar.
My mistake, there are 2 options to set, it's now working.
It's pretty poor though, only dips a tiny bit
turn the car ignition on, but don't start the engine.
put mirror switch into L position.
put car into reverse, set mirror position to dipped position.
take car out of reverse and turn off ignition.
I think that's the process to set the dipped position.
This only works if you have Eletric memory seats. You can get the Mirror to dip by putting the switch to " L " whilst reversing. The mirror only dips about 5 to 10 % and doesn't always go back it the correct position when going forward
Edited by Auric Goldfinger
Yeah that's the problem I have, so it's now switched off.
