Cornering fog lights on Octavia lll Facelift
There are three different methods on O3 FL to activate cornering lights. Sometimes it is not sufficient to change the adaption in Leuchte12 and Leuchte13. On vrs it is for examples Leuchte2, Leuchte3, Leuchte4 and Leuchte5. Further there had to be change some adaption in the config adaptions of cornering lights
  • 3 months later...
Can you please  share details on the config adaption needed for non vets O3 FL.
where to find them and what to do?
I am also trying to enable them without success. Something is definitely missing.
If you have vcds than make an admap from controller 09 and send it to me in pm. I will look on it and send you back the right coding
Edited by djduese
I am using obdeleven
Ok. Write me in pm. I need photo from Leuchte2SL and leuchte5TFL.
And photo of Cornering_Light_Adaptation
  • 1 year later...
Hi ccosmin, have you had any luck activating the cornering fog light.? I am in the similar situation. I bought 67plate Octavia with LED front and back light few days ago. the ususal coding is not working for this one. please help me if you can. thank you.
Did you have a read of the thread on the OBDeleven forum? Some info there about setting temperature values.
Caveat: i've not done this mod on a facelift car (yet) considering doing it on missus 2019 car with LED lights if she keeps it after PCP.
Could you give me the link? I seem to not find OBDeleven forum.
Its the one you posted in yesterday. The answer is only about 5 posts above your question.
But that was for VRS though? mine is SE L trim
Thanks lway. it was very useful and finally I got my cornering lights working. now need both rear fog lights activated.
