Bluetooth not working on Bolero
Hello.
My 2014 Superb has BT installed. Everything was  working fine until about a week ago. Since then, the PHONE button just mutes the stereo, no phone menu comes up. The phone shows it is connected but the calls go to the phone itself instead of the system. What could be the issue? I've tried two phones, Iphone and android, and tried resetting to factory settings.
Looks like BT module or Bolero has some issues. Does your Bolero switch on/off when you engage and disengage ignition? Are you able to adjust the volume from steering wheel? If not then there is an issue between your Gateway and Bolero. If yes then try to locate and remove fuse for Bluetooth (or remove for few seconds plug from Bluetooth module).
Hello.
The unit switches on and off with the ignition, and the volume control also works. Can you guide me to which connector is the BT unit? I read it is under the driver seat but there are a lot of connectors there.
Bump
http://bfy.tw/GA1i
Then click the Videos tab. First result...
Hello
Did the unit reset, didn't help.
Any other ideas?
VCDS scan to check for relevant faults, then possibly a new Bluetooth module.
  • 1 year later...
Hi there I have this problem volume not working on steering wheel and Bluetooth not coming up or some times for 5sec and then disappears ,what you mean by  between your Gateway and Bolero, Skoda Superb MK2 L&K
Many Thanks
It can be faulty gateway, broken cables...
Have you recently had a software update or changed coding to anything on the car?
Have you recently added a new user in Bluetooth?
Have you tried to pair a new phone which has filled the user spaces on the Bluetooth?
Have you unchecked a setting by mistake in the driver information display (DIS)?
What has changed on the car since it last worked?
Has another user (Bluetooth) driven the car and it is defaulting to searching for their phone?
When a call comes in, select the car for audio source from you phone instead of your handset.
Can you add pictures of what you see on the radio and the phone settings in the DIS, it may help someone spot something.
Keep it fairly simple first ie phone settings etc prior to spending out on diagnosis at a garage or fitting parts to try.
Edited by 3T51704x4
Hi there,Bluetooth shows on dashboard and after 10-30 seconds disappears, sometimes not come up at all.
Can you scan the ecu and say which software version it is, will check if any updates avail prior to spending out.
I don't have any tools,☹️
Ha, I was reading the OP then noticed the post date doh 🤣
Edited by 3T51704x4
Bolero with Delphi manufacturer software 008
Bluetooth issues
Software version 012 from week 22 in 2013 all radios were updated for Bluetooth issues.
Superb 3T Bolero 3T0035156F But you need a measure code to implement it so only dealer can update it through normal channels.
Dont know if it will fix your issue, it really needs a scan to have a better understanding of what’s going on.
Edited by 3T51704x4
Telephone not displayed in maxidot
fault 1303 Telephone Transciever No comms
Week 45 2011 on modified phone control unit to fix.
Parts from TPS will be the latest version.
Says this can happen due to volt drop on vehicle network eg when starting.
  • 1 year later...
Hi Folks,
Unfortunately i have the same issue even after unplugging the system was there any fix on the below problem ?
It was working and seem to have just switched and stopped working. It will connect but no display.
I have to chime in as well, have a 2010 superb with bolero unit, I have Bluetooth in it and it worked when I got it used several years ago, but at some point it just stopped working, and now I'm thinking about really getting it to work again.
I have tried unplugging, I have checked fuses (I think I have managed to check everything that has to do with phone or Bluetooth)
Is my next option to search for a replacement BT unit?
I have found one locally here in sweden but it's very pricey for a used part, the ones that are cheaper on eBay etcetera look to be in very poor condition and older than my car is.
  • 2 months later...
Hi all,
Is there any specialist or anyone who can help regarding the bluetooth update for Skoda superb mk2?
The head unit is 3T0 035 680 A on the label, but on the secret menu, it shows 3T0 035 680 G.
The telephone module is 5N0 035 730 B and I tried to replace it with 1K8 035 730 D for bluetooth streaming music and also because I don't like rSAP mode.
With the new module, the bluetooth is not available at all, I can't connect my phone, I don't even have the setting menu, and the phone button just put the unit on mute.
I have changed the coding using VCDS and there were no errors after.
I would like to know if it's just incompatibility or the new (used) module is faulty and if can do anything about or just need to a different one starts with 3C0?
Might be worth posting an autoscan @SKD_VRS to give an idea of any fault codes and how your car is configured...
Hi again
Chassis Type: 3T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62
          72 77
Mileage: 48647miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 QT    HW: 03G 906 021 AB
   Component: R4 2,0l EDC G000AG  2617
   Revision: --H11---    Serial number:
   Coding: 0000078
   Shop #: WSC 33361 790 00000
   VCID: 010E1D2B581AAD3652-8054
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1917
   Revision: 04844002    Serial number: 00000908031314
   Coding: 0000020
   Shop #: WSC 35110 377 00999
   VCID: 51AEED6BC8FA9DB682-8004
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 3T0 907 379 C    HW: 3T0 907 379 C
   Component: ESP MK60EC1   H45 0104
   Revision: 00H45001
   Coding: 863D6016092300FE611106E790190082AA00
   VCID: 3D76A1DBA46209D676-8068
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 030217238A06BF2640-8056
1 Fault Found:
13636352 - Control module not coded
          U1013 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 78297 km
                    Date: 2021.06.28
                    Time: 18:00:41
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 E    HW: 1K0 937 087 E
   Component: BCM PQ35  H+  103 0541
   Revision: 00103 AE
   Coding: 48990AB8F841F1C040080084110089A401711BAE632085605C4040000000
   VCID: 336287E39226CFA690-8066
   Subsystem 1 - Part No: 3T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 31070  22  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 240809 05  54  0402
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 3T0 919 475 B    HW: 3T0 919 475
   Component: PARKHILFE PLA H07 0004
   Revision: --------    Serial number: 66430921903554
   Coding: 001104
   VCID: 3C70ACDFBF7800DE41-8068
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 A    HW: 3T0 959 655 A
   Component: J234__LC0 VW10 HI   1916
   Revision: 18013000    Serial number: 003EAPGWS1MM
   Coding: 0017200
   VCID: 3F8ADBD36E6E1BC664-806A
   Subsystem 1 - Serial number: 6332MTS601792249
   Subsystem 2 - Serial number: 6342MTS638742239
   Subsystem 3 - Serial number: 6351HTS6MR8KV8KR
   Subsystem 4 - Serial number: 6361HTS6BABKV8KR
   Subsystem 5 - Serial number: 63727TS6AEQ4V8KJ
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0001731
   VCID: 76E47EF701D49A8E77-8022
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0012
   Coding: 00000130
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 941 D    HW: 3T2 920 941 D
   Component: KOMBI         H06 0110
   Coding: 410F00
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3664BEF78954DA8EB7-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 5223
   Revision:   H16       Serial number: 4120K098250B8C
   Coding: EDA1FF06400602003303
   VCID: 66C42EB751746A0EC7-8032
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 78297 km
                    Time Indication: 0
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H06 0110
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: 72EC42E76DBC86AE5B-8026
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 G    HW: 3T0 035 680
   Component: RNS-MID       H11 5238
   Revision: AB001001    Serial number: SKZ6Z7J7233086
   Coding: 04000400040400A10000
   VCID: 346084FF9728C89E89-8060
   Subsystem 1 - Part No: 3T0 051 859 AT
   Component: EU West V16  8536
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 196    3001
   Revision: 00H17000
   Shop #: WSC 20022 210 92354
   VCID: 316E8DEBA83AFDB6E2-8064
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
   Component: TSG BF        H03 0200
   Revision:             Serial number: 0000101689763
   Coding: 011D0220DE01121002
   VCID: 3F8ADBD3AE6E1BC664-806A
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1377095
   VCID: 346084FF5728C89E89-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000021
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795     HW: 7N0 959 795
   Component: TSG HL        H02 0200
   Revision:             Serial number: 0000101733815
   Coding: 010C00200001221002
   VCID: 010E1D2B981AAD3652-8054
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 B    HW: 5N0 035 730 B
   Component: J412                8502
   Revision: 00015000    Serial number: 0000B7A102016
   Coding: 0020121
   VCID: 275A63B396FEB3063C-8072
End
