Aftermarket spare wheel options
 does it look anything like this picture ,has your 4x4 got a wheel well or is it a flat surface?
  • Replies 125
  • Views 35k
  • Slight Update to this, tried to order the parts separately as Womanofkent did but was told by the parts dept that the wheel could no longer be ordered separately! They could order me the kit for £260.
  • womanofkent
    womanofkent
    Sorry another update went to collect spare wheel today the jack wasn't supposed to be there but the parts chap had found a different code for it.   Total price was £187.41 all in.
  • Horacecoker
    Horacecoker
    When that happens, I'll just ring the AA and let them tow me to the nearest garage. I would never ever entertain the idea of of changing the wheel myself at the side of a road - them days are over wit
Yes, just like that.  No wheel well, the skinny spare just sits on the floor.
Note amount of room around the spare.  That allows a proper sized tyre to fit in nicely and this is my plan for full sized spare.
Just got to sort out how to sort out supporting the floor either side of the wheel in there.
PS But remember mine is a 4x4 version so my floor is a good bit higher because of the 4x4 gubbins.
Edited by DSL
Thanks you very much for sending the pictures, the karoq I have has a wheel well, so hopefully purchasing this kit will raise the floor level but will be flat and level.
To support your floor may I suggest the use of polystyrene insulation block which is easily cut with a knife to the shape you require.
Just had a measure of the polystyrene bit of the spare wheel fitting kit and it’s 10.0cm deep.  That should let you see where the boot floor will sit with the wheel in there.  If it was me, I’d bung the Ratikon you have in there and see where 10cm above the side bits of the floor will take you wrt the side wall of the tyre.
Hi
Just got the parts today,they fit very well into the space with the full size wheel.see attachment.you do loose some boot area but it's worth while having that piece of mind.20200923_122102.thumb.jpg.0b65b3a8d145a2d15269803c9c8f5b45.jpg
Just, literally, got my tyres mounted on the 2 spares, wish mine would fit as well.  Somehow don’t think this isn’t a long term solution!!
Had a search but can’t find the answer but are the polystyrene parts available without all the jack bits and pieces?  Thinking one set on top of the other would fit the bill for my needs, plus would provide a few cubby holes for bits and bobs to fit in.
PS Found it, 57A093860A.
Edited by DSL
Think that part is c.£90? (£77.50 + VAT?)
Agreed, will have a think as to whether it’s worth that.  Also as my local dealer (Inverness) has closed it’s not quite as simple.  Might see what Horton can do.
The part number for the kit is 57A093860A.
As I said before I have a 2wd and this kit is basically for the 4wd but does if you are using a full size wheel on the 2wd.This kit comes complete with tools.
Is there a car scrap yard near you, you may be able to just pick up the polystyrene bits at a fraction of the price.
The other option is go to B&Q they have polystyrene loft insulation blocks ,use your existing polystyrene as a template and cut o size.
Thirdly phone Skoda customers services  and ask them if they could provide you with these parts, they are very helpful
The kit cost me £95.and it came with all the bits and pieces which I needed
Why not find some thick polystyrene blocks used for packaging and stick them together to form spacers the right height. Place under the trays you have already  to support at correct height.
They can be filed to the correct thickness and should cost nothing. Then when you lift the floor it will look as though it was  meant to be like that.
Once correct stuck them to the tray underside so it all lifts out in one piece.
Yes ,that's another option.
Looks like I’ll be going down the cheap route.  100mm thick insulation board/kingspan, cut to the shame of the fitted pieces then fix the factory fitted pieces on top.  And much cheaper!!!  Plus I’ve got a Travis Perkins just up the road.  Plan starting to come together, thanks for the advice.    :thumbup:
Oh, and winter tyres now on the rims and said rims on the car so let it snow, let it snow, let it snow. :D
Edited by DSL
Silly question maybe, but I have ordered a spare kit for my 4x4 with the space saver.
If I ever use it does the cover still sit on the full size wheel which will need to go in the boot?
In the Yeti the cover had a hinge arrangement to let it sit flat but higher.
Slightly concerning as the car will regularly do long trips to Norfolk from Leeds and full of luggage. So with the normal punctured wheel in the boot will the floor not be supported properly to hold the luggage? Sitting on wheel in centre but sides not supported around wheel?
With a full size wheel the the boot mat will sit on the wheel but there is no support on the side or back, that's why u need to add extra packing to raise the level of the existing  polystyrene to the level of the wheel.
Sound like you’re trying to do what I’m trying, the boot floor will sit like below.  You’ll loose 10cm in boot depth.   I’ll be supporting the sides better once the polystyrene/kingspan is under the black pieces.  I’ll also get a piece of pipe to extend the plastic disk piece so it supports the load.  Then I’ll be able to load up the boot properly and should support the stuff whatever tyre is in there.
Karoq Sportline spare wheel sorted today. 18” temp spare new and unused from a 20 reg Karoq £40 plus fitting kit from ŠKODA dealer at £90. Have retained original emergency repair kit and will replace In vehicle and easily sell full spare wheel kit at end of my personal lease. £130 for peace of mind.
I don't have a spare wheel, it takes too much space from the boot, as the 4x4 has no well for it.
Also, the last flat I've had was over 40 years ago.
Also, loose nails aren't used much these days.
Also, at my age, changing a wheel isn't an easy task. I'd need to call for help anyway.
Today, on my walk, I found two sparking wood screws on the road I regularly drive on.
:sweat:
Edited by agedbriar
I thought like that and have not had a spare wheel in Yetis for last 10 years. Had 4 punctures i that time, fortunatley 3 on drive noticed next day. Still a pain to get fixed.
However have just fitted a space saver kit to my new Karoq 4x4 and it is nowhere near as bad for taking space as that in the Yeti. For a start it is a true spacesaver and much narrower than the Yeti standard spare which was still limited to 50 as different to other wheeels.
Now if i have a flat out of hours the AA can fit the spare, you can only realistically get a wheel repaired or replaced during working hours.
I did have a blow out on A38 once and AA took me and wheel to Kwik fit to get a new tyre. Don't know what would have happened out of hours. Very time consuming to be relayed home if no spare.
I would also think twice before changin a wheel at side of road now.
It’s the time consuming side that dictates I want to carry a full spare.  I do regular(ish) 560 mile drives and getting a puncture on one of those would mean trying to get a tyre replaced mid trip, turning a one day drive to at least one & a half, if not two, day haul.  Plus chances are it’ll be a Sunday so less options.  No, full spare swapped, by RAC or me, and journey continues without too much hassle.  Then sort out replacing or repairing puncture pretty much at my leisure.  I don’t mind the extra depth it takes up in the boot by fitting it to the skinny spare mount, means it’s properly secured and not going to shift around.
I know it’s risk vs consequences and last time I had a non off-roading puncture was a long time ago but not worth worrying about having to cope with skinny spare if I got a puncture in what could be pretty extreme conditions.  :thumbup:
On 30/09/2020 at 15:55, Bobspence said:
Is that a Yeti wheel well?  At least it’s got a sensible tie down eye, sadly lacking in the Karoq.
That looks the same as  the spare wheel kit you get for the 2wd.
Coming of the question about spare wheel kit ,gasanyone fitted a rain wind screen visor to there windows.I am  finding that when it's been raining and you open the windows the rain drop from the roof come straight in and run along the sill and drop on the window buttons.
It’s a 2 wheel drive Karoq Sportline. The wheel centre security bolt comes with the fitting kit and helps support boot floor.
