ELECTRIC WINDOWS (AGAIN)
Both sides stopped working today. I've learnt from this brilliant forum that it's probably the regulator in the o/s door. But before I start spending money and drilling out rivets to remove the carrier, etc. I was wondering, if luck was on my side, are there any quick fixes I should look for first.
Also, advice on where to buy a regulator would be much appreciated. Thanks very much.
  • Sponsor
Window motor module is accessible with just door card removal, isn't it? No unrivetting required?
Sorry, I meant motor/control module, not regulator  (it's a good job that Wino knew what I meant!)
You should definitely check it's not a blown fuse before you start tearing the door card off.
  • Sponsor
^ Good tip.
Also check for broken wires in the door bellows.
