Sump plug size
Hi I’m not 100% sure on the thread size of the 1.9tdi sump plug.
I need a helicoil kit I think it’s m14x 1.25 or m14 x1.5 does anybody know. This is for the 19mm head sumpplug
M14X1,5
Brilliant many thanks
  • 3 years later...
Morning guys, is M14x1.5 18mm too short? (Mk1 vRS)
cheers
cheers
OEM Part Number: N90813202
Specification: M14x1.5x22
21 N 90813202 seal bolt with sealing ring M14X1,5X22-TC-
S20
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2003/drive_standart/252/hg_ug/103/subcategory/103010/part_id/2541323/lang/e
This is a very common sump plug that is used in the following Skoda models:
Skoda CIT Citigo 2012 2013 2014 2015 2016
Skoda FAB Fabia 2000 2001 2002 2003 2004
Skoda FAB Fabia 2005 2006 2007 2008
Skoda FAB Fabia 2007 2008 2009 2010
Skoda FAB Fabia 2011 2012 2013 2014 2015
Skoda FAB Fabia 2015 2016
Skoda FABI Fabia 2009 2010 2011 2012 2013 2014
Skoda OCT Octavia 1997 1998 1999 2000
Skoda OCT Octavia 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011
Skoda OCT Octavia 2004 2005 2006 2007 2008
Skoda OCT Octavia 2009 2010 2011 2012 2013
Skoda OCT Octavia 2013 2014 2015 2016
Skoda RAP Rapid 2013 2014 2015 2016
Skoda RAPI Rapid 2012 2013 2014 2015 2016
Skoda RO Roomster 2006 2007 2008 2009 2010
Skoda RO Roomster 2011 2012 2013 2014 2015
Skoda SUP Superb 2002 2003 2004 2005 2006 2007 2008
Skoda SUP Superb 2008 2009 2010 2011 2012 2013
Skoda SUP Superb 2014 2015 2016
Skoda YET Yeti 2010 2011 2012 2013
Skoda YET Yeti 2014 2015
http://www.oemepc.com/tvn_result/search/tvn/N 90813202
autodoc.co.uk lists these sump bolts in various aftermarket brands for under £2 each.
109 035 TOPRAN with seal ring, Spanner size: 19, Thread Size: M 14 Sealing Plug, oil sump 109 035 cheap
https://www.autodoc.co.uk/topran/2724721
N90813202 Topran Germany (£1.69 including postage on ebay)
https://www.ebay.co.uk/itm/114843270361?hash=item1abd313cd9%3Ag%3AG0cAAOSwaE9gv4s3&LH_ItemCondition=3
Edited by Carlston
Cheers Carlston. Can get today from wuro car parts, this looks the same im thinking
I don't really understand why you need replace the sump plug, it's steel with a captive steel washer.
Ive been down this road myself ! I fitted an M14 x 1.5 VDO oil temp sensor and brass washer in place of the sump plug.
I change the washer every service and it doesn't leak - yet anyway !!
I had all the bits from a previous life and enjoyed fitting them but whether there is any useful info from them is another matter !
I'd agree, but for circa £2  I don't take the chance. Possibly this is a way for dealers to jack up the cost of an oil change. Possibly it's a side effect from the use of using compression washers else where. After 50+ years of driving ( and doing most of my own servicing on a lot more cars than I've got fingers) ,I've only changed a sump plug in one old car .( Head was damaged ).  Never had one leak, or had any other problems even on one that had an aluminium sump.
But dealers change them?????????????? Possibly a chance to think about re-using the old bolt and investing in a torque wrench, with the number of posts about sump plug problems.
But why ( unless [ enter name of usual local big name motor store] is close by) why not just hop down to local motor factor and check out their price.
Edited by VWD
addition
I think the dealers probably fit a new one because they're used to the apprentice dropping the old one and losing it so it's more efficient to simply replace it.
I thought I was alone in never replacing them TBH. Unless they've been tightened to Ape strength and they're ruined, they go again, time after time. The sump material being alloy is softer than the washer so it tends to find it's own seal perfectly well.
I found with apprentices that you never gave them anything you did not want them to loose. 😁😁
