Hail and storm damage fault codes
Hey hoping for any suggestions on what the root cause of all the faults I’m getting on my VCDS scan.
I’m currently in the Netherlands and am meant to be returning to the uk on wed today.
however whilst coming out of Utrect on Tuesday the lovely sunny 31c day quickly turned to severe rain and hail, there is some cosmetic damage to roof and bonnet from the hail which I will worry about later.
My main issue is whilst driving I had the following flash up on the maxi dot:
error:  brakes workshop
error: acc front assist
error: tpm
error: esc stability
error: light bend
in total 7 faults appeared and the car is constantly making a bing sound as it flashes up with errors every 1-2 seconds.
i suspect it’s water ingress due to the amount of rain water build up on roads, at one point I couldn’t see the kerbs and had nowhere to pull over to.
On checking the car with vcds im getting loads of faults across several control units. In addition to the faults the brake lights are flashing on and off, which is a real pain as this makes the car unsafe to drive effectively stranding me in Holland.
Going to try and see if I can get skoda to look at it but wondered if anyone had any idea what would cause all these faults?
Tuesday,29,May,2018,22:13:07:12030
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN:  xxx  License Plate:
Mileage: 64996km-40386mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F 6D A5 A9
VIN:    Mileage: 64996km-40386miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EM    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7543
   Revision: 83H22---
   Coding: 111D0032036501080000
   Shop #: WSC 51923 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021EM 002008
   ROD: EV_ECM20TDI01104L906021EM.rod
   VCID: 74C90EA9DF95D1E433-8020
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 040 J    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4027
   Revision: 05652104    Serial number: TFK01307301754
   Coding: 0014
   Shop #: WSC 73430 031 00209
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1E1D0C0101992BB435-804A
1 Fault Found:
21223 - No Communications with Power Steering Control Module
          U0131 00 [002] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 T    HW: 5Q0 907 379 H
   Component: ESC           H31 0556
   Revision: 00000000    Serial number: 6216300000035D
   Coding: 1C07939154250973007C060641C82938C92A9000608294F4F6615072C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
   VCID: 4DBFBB4D1CFFE02C9C-8018
3 Faults Found:
8242 - Databus
          U1121 00 [008] - Missing Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 21:56:39
8289 - Databus
          U1122 00 [008] - Implausible Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 22:06:47
16390 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 21:55:59
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 C    HW: 5E0 907 044 C
   Component: Climatronic   H02 0604
   Revision: 00001K06
   Coding: 02110104000100011005000100100000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_SK37.rod
   VCID: 256F23ED24CFF86C74-8070
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011322402501
   Coding: 0F001B66C2C722FB0FA44086B11C17280008000000000000000000000000
   Shop #: WSC 73430 790 00209
   ASAM Dataset: EV_BCMCONTI 011001
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77D339A5CEE3BAFC16-8022
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130802  041 0570
   Serial number:         130814223203
   Coding: 065DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS  024 0042
   Serial number: Y13M08D26H10M51S57S1
   Coding: 06885D
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY131560L70
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000027674554
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131322100889
   Coding: 0131061051
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_003_AU37.rod
   VCID: 3D5FEB8DAC5F50AC0C-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 19081376510203
   Coding: 000C1600FE0309
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   ROD: EV_ACCMRRBoschVW372_VW26.rod
   VCID: 354FF3AD946F88ECC4-8060
2 Faults Found:
0275 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 254
                    Reset counter: 132
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 22:06:06
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 12.1 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 22:06:05
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P4PH5E4LW
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F23D185E6D382BC5E-802A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 208 13
   Component: SideSensor_Df  008 0887
   Serial number: 3576U0000002340D6D06
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 001 208 13
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U0000004810D6D0B
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 800 908 13
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R922CC001000000.
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 800 808 13
   Component: SideSensor_Pr  111 0148
   Serial number: 3526R92189801000000
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 807 13
   Component: FrontSensor_D  114 0149
   Serial number: 3556V45209701000000Z
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AQ    HW: 5Q0 953 549 A
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 21081308491426
   Coding: 6C00
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 052F436D840FD86C14-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 971 F    HW: 5E0 920 971 F
   Component: KOMBI         333 2210
   Coding: 27AD09086D94A60001887A03000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
   VCID: 2C79D6C94725C924AB-8078
1 Fault Found:
12858137 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 99
                    Reset counter: 132
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 21:50:29
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000836979
   Coding: 030100040B087300EF00067A1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear_009_VW37.rod
   VCID: 3B5BE595B24B5E9C32-806E
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000C1136140813
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 4490690903
1 Fault Found:
65794 - Data Bus for Suspension
          U10AE 00 [009] - 1-Wire Mode
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 22:03:09
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000073486086
   Coding: 001C08208001020000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 558F532D342FA8EC24-8000
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000477514
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 9301
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 334BCDB59A1B96DCEA-8066
Address 47: Sound System (J525)       Labels:* None
   Part No SW: 8V0 035 223     HW: 8V0 035 223
   Component: MIBAMP1ALPINE H11 0300
   Serial number: SKZ8Z1D760062LA
   Coding: 03730200AA002AAA00
   ASAM Dataset: EV_AMPMst16C2ALPI 004016
   ROD: EV_AMPMst16C2ALPI_SK37.rod
   VCID: 6DFF1BCDBCBF002CFC-8038
1 Fault Found:
6693 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 132
                    Mileage: 64991 km
                    Date: 2018.05.29
                    Time: 16:52:14
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000073209532
   Coding: 001C00208C01020000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000489410
   Coding: 050200
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0080
   Revision: --------    Serial number: --------------
   Coding: 03DE02003F010000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
1 Fault Found:
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 21:52:28
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-HGH1.clb
   Part No SW: 5E0 035 020 A    HW: 5E0 035 020
   Component: MU-H-ND-EU    H41 0196
   Serial number: A313H0D7506567
   Coding: 03735201000000002111120200A800002F0001260100010076
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_SK37.rod
   VCID: 150F132DF4AF68ECE4-8040
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H50 0022
   Serial number: SKZ8Z9NL1006AL
   Data medium:
   Subsystem 2 - Part No SW: V03 959 800 MF    HW: -----------
   Component: ECE 2016  --- 0134
   Serial number: --------------------
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 5E0 959 107     HW: 5E0 959 107
   Component: HDSG-Modul    H01 0744
   Revision: 42001001    Serial number: 218300323
   Coding: 1233074002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 69F76FDD88571C0C90-803C
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0050
   Serial number: 00000100713
   Coding: 0101010001030303000400000100010100
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3A55E091BD71679429-806E
2 Faults Found:
4587520 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 64
                    Reset counter: 132
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 21:54:35
                    Control Module temperature: 44 °C
                    Outside air temperature: 26.5 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 12.2 V
                    Terminal 15 on: 1232.6 s
5636096 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 132
                    Mileage: 64996 km
                    Date: 2018.05.29
                    Time: 21:55:10
                    Terminal 15 on: 1266.9 s
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 130806200556
   ASAM Dataset: EV_SoundActuaGen2AU64X t003010
   ROD: EV_SoundActuaGen2AU64X.rod
End-------------------------(Elapsed Time: 03:57)--------------------------
Edited by ollybroad
Removed vin
Wow, that’s bad luck! Someone will be along with more knowledge than me soon.
I know an excellent dents man in the SW who will sort your hail damage for you. PM me if you want his details.
Good luck getting it sorted.
Have you tried clearing all fault codes and seeing which come back as some of those are intermittent.
Yer tried clearing the faults the above scan is what keeps coming back.
took it into skoda this morning and they tried clearing faults to no avail and are unsure on what the issue is.
i’m wondering now what with hail damage on roof and bonnet plus the electrical issue if calling the insurance is now the best option?
Is it worth trying disconnecting the battery and reconnecting?
Looks like some kind of databus issue, dropping the battery off will reset all of the modules which would be worth a go.
Is the roof damage severe enough to have damaged any of the databus cables or for the roof to touch any of the modules in the roof?
I would say there are so many faults there, it sounds like water has got into an ECU or similar control box (Doors would always be a good candidate)
If the hail had damaged the wiring, you'd have some pretty serious bodywork damage.
Someone had something similar happen on a Superb 3 and it turns out it was caused by rodents chewing through the wiring loom.  Hang on I'll dig out the thread.  The weather is likely the cause but the faults generated look pretty similar so it's worth a look IMO.
Here it is:
No they are only shallow indents, just annoying more than anything.
Anyone know where the car reads speed from? Is it what I would call the abs sensors on the hubs?
speedo wasn’t working but has started to periodically work and when the speedo is working the error:brakes doesn’t show and the rear brake lights stop flickering.
The water wasn’t high enough to get into the evy and engine bay is dry, can only assume it’s a sensor or similar low down like abs, steering angle? But only stabbing in the dark at the moment.
I'd expect it to be the four ABS sensors on the hubs. You can use the measuring blocks in VCDS to monitor all four on a short drive.
Certainly feels like water has gotten somewhere it shouldn't, hard to say where though :/
Edited by langers2k
All the faults look ABS related...
Don’t forget that water drains into doors etc in heavy rain and in theorist should drain out again.
there used to be electronics in the door/boot etc, so rather than high water I would suspect sheer volume of falling water.
lots of the messages are implausible ones, so it could be one device on that bus that is going mad and messing up signals from all of the others.
Sounds like a nightmare!
I haven't a clue how the systems work or what VCDS is highlighting, but you mentioned one fault that popped up -  error: acc front assist
Rather than delving into the depths of water ingress playing havoc with the software management,  could it possibly be something as simple as the front sensor on your grille being damaged?  Often experience the ACC front assist message being displayed during heavy rain on our SEAT - all OK again when the rain goes off, but just thinking hail may have damaged it?
Could those other error messages be related to this sensor too? I'm assuming auto-braking system will also use it?
I can't even guess what 'light bend' is tho.
Edit:  Ok I will take a guess. Could hail have damaged the windscreen which means the camera sensors are being fed false information?
Edited by Guest
Good point, will have to remind myself how to use the measuring blocks been a while since I’ve with vcds. I am thinking abs is a possibility!
Agree!
Yer i was thinking similar
Have you posted that scan on the Ross Tech forum? They might be able to assist with some of the errors....
Also, these " [New feature! Extended UDS fault detail is only supported by current gen. interfaces]" are because you need the latest VCDS cable to work with the Mk 3 Octavia so not sure that is skewing the results?
Edited by Plantman
