Speedo reading in Km/hr
OK as a Landrover Freelander ownner I also have a Haldex in the drive train.  I am not sure if it's exactly the same unit as the Freelander has quite a sophisticated 4WD system with different modes for snow, gravel etc  however  whereas Landrover don't specify any Haldex oil/filter changes in the service schedule I understand that VW does.  Is this true in the Yeti ?    Also what sort of drivetrain problem do people get with the 4WD Yeti system?
  • Replies 51
  • Views 7.7k
  • You should find all you need here https://www.briskoda.net/forums/topic/229766-vcds-adaptations-how-do-i/
  • Not true.   The law states that the car must be capable of displaying both MPH & KPH.   Get someone to code the car to ‘Australia' and you will get the large MPH, all the info
  • I don't see what all the kerfufful about law is about!!! If the car is coded with VCDS or whatever both MPH AND KPH are still available to view on the Maxidot as is the case with most new cars.
Oops only joking
