Speaker issues
So I've found that my speakers don't seem to be working on the driver's side RHD model, and when I've messed about with the settings in the pid for the fade there's a loud ticking noise coming from behind the dash? I'm pretty sure there isn't any speakers behind the dash? Has anyone had the same issue? Thanks
UPDATE - It only seems to happen when I'm using Bluetooth via the pid? Seems like a weird fault but I know there's common faults with the pid Bluetooth
Is it all sound from the PID - do you have a memory card in there to test? If so it might just be the pins on the holder where it clips in the the dash need a clean or are not in contact properly. try removing and re-seating it to start.
Edited by greenstripe
Typo
It's ok Ive just switched to using an AUX cord there seems to be a lot of issues with the Bluetooth so I think an AUX is the best Solution
