What brake DISCS / PADS combination?
Hello guys , what brake setups do you have? What would you recommend?
Thinking of  Zimmerman's sport drilled + ate ceramics.
For the Aussies -
just fitted up the following to my 09 vRS TDI
RDA slotted and dimpled
RDA heavy duty pads
braking power strong, no fade to note.
a bit of squeal which we're putting down to dust in a dimple or slot
probably should have gone softer pad as the car doesn't get driven too hard these days.
brake feel great when warm, a bit wooden on cold application then start to progressively bite.
again, probably should have gone standard RDA pad.
I put Pagid disks and pads all round on our VRS CR. They have been pretty good over the last couple of years. Due a brake fluid change soon.
Normal spirited driving at times.
Edited by FatblokeVRS
I try to use Pagid discs and pads on whichever car I own - they may squeal a little at first, but I have found them to be strong and progressive.
Pagid pads and discs all round on 1.8 tsi L & K, they work strong and progressive with no fade at all.
Looks like pagids winning then :) thanks for your replies guys :)
