XDS Settings
I enabled XDS on another members Superb earlier this year but he has found the 'Standard' setting too invasive.
The options on VCDS if I remember correctly are Standard, Weak, Medium and Strong (and Not Activated).
Weak and Strong are self explanatary but is Medium stronger than Standard or weaker?
  • 2 months later...
Could you post the steps to enable XDS on Superb using VCDS ? Is some specific ABS/ESC controller H/w required ?
Only certain abs units support it.
Posting a full autoscan from vcds is a good starting point!
Here's the info on my ABS controller.  Need to dig out full scan later.
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 60937000000878
   Coding: 1D07929C34200B6C477D060940CB49B8492CD0E2600292352043F0044002420000000012121212B835351919323200
   Shop #: WSC 33361 790 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
   VCID: 78A91614825156C7621-802C
No fault code found.
Liger would have activated/tweaked it on a MK2. You look to have a MK3 which has a completely different ABS pump with a much longer lcode.
Unfortunately, I'm also more familiar with enabling it on older MK60EC1 pump, you might want to search for MQB xds activation :)
  • 4 weeks later...
Thanks for clarifying. Will search for MQB XDS activation ...
S
