Boot plastic trim replacement
Does anyone know the part numbers for the plastic trim which surrounds the boot on the hatchback. Not the tailgate but the actual boot sides there is a piece of plastic each side, and 1 across the bottom by the boot lock, all mine are hanging off and scuffed and wanted to replace them as the rest of the interior is pretty good.
Had a look at some etka but couldn't see these parts.
Isn't the number moulded on the back of them?
probably, but thought rather than unscrewing everything for the part number to find out they are £50 each of something wasn't worth it if someone knows what they are?
@JWvrs25  I'm fairly sure these are what you mean?
6Y6863459F 47H That should be the middle bit where the lock is.
6Y6864583C 47H That should be the left bit of trim that attaches to it
6Y6864584C 47H That should be the right bit of trim that attaches to it
looks like it, thank you !
No worries!
