Gunk and disk calipers
Many, many years ago I used to use "Gunk" to clean my motorcycle engine.
I want to clean up my disk calipers - what is the best way to do it?
I am aware that it is essential that I should not contaminate my disks or pads.
Edited by SeaGoat
I would recommend brake cleaner (oddly enough).
If you're going to be bother of trying to clean the calipers, do a dismantle and rebuild that way you can inspect discs and pads and avoid any contamination. Good opportunity to regrease the brake sliders and lightly grease back of pads with Copperease. You can remove any surface rust on the caliper with a wire brush, unless of course it's been painted.
Edited by spartacus68
Thanks for that, any particular brand?
As to dismantling, I have been advised to replace the rear disks (and pads).
I will not be doing that, a tame garage will.
However, as a general policy I would like to keep the calliper housing looking clean(er).
Thanks anyhow and I will certainly pass on your sensible comments to the garage.
Anything.  £2-£5.
Online, Motor Factors, National Car Part Superstores etc.   Does what it says on the Spray Can.
