2012 Skoda Fabia VRS
Hi Guys
My friend repaired a damaged Fabia VRs that had a frontal crash and the steering pump had to be replaced. However on replacing with a second hand part we are getting the following error
Power steering sensor G250 Open or short
Could this be a sign that the replacement pump is faulty? Also the where is location for the G250 sensor? Is it on the rack or pump itself?
Also noticed another thing was that the pump has 3 connections but on the VRS only 2 of them are used? Any clue as to why?
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10111
   Shop #: WSC 61721
   VCID: 6D87CBBA04D278CF45D-8038
1 Fault Found:
00816 - Power Steering Sensor (G250)
            30-00 - Open or Short to Plus
Edited by singh946
1 hour ago, UrbanPanzer said:
Will the fault not clear then ?
http://wiki.ross-tech.com/wiki/index.php/00816
Steering sensor nothing to do with ABS, sure the fault was not already there due to the crash ?
Sorry mate meant to say the steering pump was replaced which is on the left hand side.
I have tried clearing the code but to no avail. Where exactly is the sensor? Also steering is a bit stiff....as mentioned in the ross tech link
So as mentioned in the ross-tech info,
Was the replacement "identical" to the original part ?
Well checked the part numbers (which I had completely forgotten to check doh!) and it seems there is a difference of a single alphabet in the end as it has a 'J'. So in the end he has ordered a replacement like to like now making sure all part numbers are same. Will have to wait and see the end result.
