05 Fabia classic HTP Central Locking issue (not remote)
Hello,
Just wondering if anyone knows if this car (05 Fabian classic Htp) should have central locking via turning key in lock (not remote), we have two keys of which none had a fob but when put into the drivers door it will only open the drivers door or passenger door. We are not sure if it ever had central locking because we have only owned it a short while (car was a bargain so this is a minor issue I was hoping we could sort of needed)
I was thinking that it should at least open the passenger and rear doors? The boot is on a release from inside so happy that it does not open this, also we can open all the other doors from inside so no major disaster.
Just wondering if it should open the other doors and if this potentially is an easy fix or is it going to be a pain in the arse ha ha.
Any help would be greatly appreciated, sorry not sure what other info I could give to help the situation.
Thanks in advance
bluedustyM
Classic is the basic trim spec. so it doesn't necessarily have central locking.
Does it have this switch on the drivers door?....
If you can find build spec - either in front of handbook or stuck into boot floor - you may be able to identify locking method from this site :- http://vag-codes.info/vag-option-codes
Hi TBM, no it does not have that switch, I though that would have just been if the car had remote central locking. I did not think about it being for manual use also
Hi Keith
Thanks I will have a look as soon as I get home.
Then you don't have central locking.
Ok thanks, the wife will just have to get used to it, don't think that will be a problem as she loves the car. Can't believe that central Locking even in manually turning the key in the lock was not standard in 2005 ha ha
Not standard on a Classic but you could have it as an optional extra of course.
One less thing to go wrong!
