Warning lights popping up galore!
:rofl:
Quite odd really - Stu's turing down of the EGR trick sadly didn't cure the EGR fault code reappearing and making the engine light come on again. And yesterday evening I had the low washer fluid beep, the low fuel beep, AND the bulb gone beep (damn nearisde dipped beam again)
Every BEEEEEEP was scaring me to death. :rofl:
How many warning lights is that now Jason? :rofl:
Well, permanent now would be airbag one. Engine light just comes and goes as the EGR faults disappears / pops up. :D
And all the rest are gone, or are solveable by topping up fluids or replacing bulbs. :D
I wonder if you could find out a bit more about the EGR cct Jason. Perhaps it just nees to see a resistance in which case you could put a resistor into the cct.
Doh!
cct = circuit? Not sure to be honest how to go about looking into anything related to it? :confused: But it came up with the same "range exceeded-EGR" fault.
Edit: Oooh, its stopped raining - time to top up washer fluid, and lose some knuckle skin changing nearside bulb. :)
Didn't you have the EGR blocked off completely? If so I'd try to measure the signal of a car that has it 'as per normal' and replicate it, should silence it then :)
Oh, it's well blanked off :D and not being unblanked for anything. ;)
Anyway, got the washer fluid topped up, but it started raining so had to quit on the bulb replacement. Gotta do it by Thursday though - MOT test. :eek:
Leave the handbrake on whilst driving - another beep for you! :D
What's the airbag one caused by? Are you running a steering wheel without an airbag or did the donor car have side airbags fitted?
