Clock Spring
Hi All
12 plate Superb Greenline Estate
Just discovered that my steering wheel controls don't work and the airbag light has lit up on the dashboard. This happened after pulling out of works car park last night where I heard a click noise from the steering wheel area. It looks like my clock spring has decided it has had enough and the wiring has snapped.
Ive priced up the part (5k0953569AL which replaces the previous 5k0953569H) at the main dealers :sad: who quoted £234
Now, my question to you knowledgeable  people is are there any other part numbers that will fit the superb (and are somewhat cheaper ) or am I resigned to paying a fortune?
Quite happy to replace it myself so thats not an issue unless anyone knows differently!!
Thanks in advance
Perhaps a used part might be a plan?
You'll also need VCDS or similar to copy the coding from the original module to the new one and make sure there are no error codes.
Why not try eBay or car breakers for second hand at that price?
I have been and the best I can can find currently is £100 for a used one. How long will that one last though is anyone's guess
So finally had to bite the bullet and buy a new one. Fitted it just now but need someone with vcds in the north west area now as my dash has lit up like a Christmas tree!
Have you tried driving it for a short distance as dash lights up like this on battery re-connection.
Then see what you have
It'll probably need coding and the steering angle sensor calibrating so VCDS or similar will be required.
Shame the old ones been removed already as it would have been handy to check it's coding first.
Good idea. Just got airbag light and glow plug lights now
If needed i can quite easily swap them back. The only difficult bit waa getting the airbag out
It gets easier the more you do of them.
the correct size small flat blade screwdriver   works wonders
Ok everyone. Mot due in just over a week and airbag light and glow plug lights still on which it will fail on. Can anyone with vcds help? I've messaged about a dozen people without any joy. Otherwise it's the stealers
Check for any VAG independents in your area: if they're any good they'll have the tools needed to do this.
