Toyo Proxes Fuel Economy?
Has anyone else noticed their fuel economy change with Toyo Proxes over other tyres? I've just had some put on the front and over a 22 mile, 60mph-ish tootle home along the M56, I averaged 75.5mpg!!!:eek: :thumbup:
I was expecting new tyres to drain more juice!
Can't say I've noticed a huge difference, if any.
When I changed mine from Conti's to T1-R's on my VRs I thought there was a minor improvement (ie 1-2mpg) however, such a small change could have been due to simply having the tyres at the correct pressure.
I think Tom saw a change in MPG when he switched tyres - however you'll have to ask him if it was up or down - I cant remember :(
Mine went down a good 5-7mpg, but it also coincided with the drop in temperature due to winter too. But also the extra confidence may have something to do with it too. I also had Neros fitted, not Toyo rubbish! :rofl:
mine went down about 5 mpg, but my grip went up - a compromise i'm happy with
I get poor mpg on toyo T1-s tyres. But now I've been using them for so long I now consider it to be average and maybe I'll get better with other tyres? I average around 45mpg without too many thrashings. ;)
my consumption went down approx 5mpg when i fitted 2 dunlops on the front
mine went down 2/3mpg when swapping the front michelins for kumhos
Same here, although recent posts on other threads seem to suggest the tyres may be 2 or 3 psi too soft anyway, so might pop along to the garage and put a bit of air in...
Hmm . . maybe I had a tailwind. :D Time will tell . . .
not noticed any difference. How the hell do you get that mpg. Went to north wales the other week with the sister in law to be following. Best I could do was 62mpg and that was trying.
I usually get 63mpg to work, that's from Macclesfield, across town, along the A537, cut down past Knutsford, then along the Northwich bypass to Chester. I do have to be well behaved to get that. On the motorway it depends hugely on speed as at 60mph I can get 65mpg (or 76mpg in this recent instance!), whenas at 80mph it's closer to 50 / 55 mpg. It was a lot better when the car didn't have the Dragon though.
I couldn't get past 63 doing 55-60mph. Must try harder :)
It may be the vRS's engine, though. Remember my PD100 has smaller injectors and turbo . . . perhaps this is why my economy is better? Drivetrain losses in the 6 speed box might be more too . . . .
oops never noticed you had a pd100 :o
