Retrofit Project
As its not possible to get car you want from stock in Ireland , I got what I can afford the best  and will retrofit as much extra I can afford :) List is doable for now:
1) ACC  as our cars have front radar  for automatic brakes , it is possible to recode/swap coding of the radar to work as ACC distance meeter as swap stalk / steering control module. Steering module is on its way.
2) Digital cockpit.  Sitting on the table and waiting to be installed/recoded. Got it here https://www.facebook.com/groups/441582886578377
3) Borderless mirror , I had one retrofitted on my SUP3 and its brilliant. Mirror on its way as well.
4) Arches black protective trim. Not purchased yet , waiting for funding :)
5) Another thing I am missing very much is front parking sensors. Did not purchase yet. Dealer denied to install and offered instead cheap Chinese  (no offence ) alternative.
6)  In some stupid reason I got Low end low resolution  RVC without trajectory :(  Need to swap to High end one , but not quite sure if I need new wiring or not.  Maybe ( I hope ) just door handle with camera swap.
7) Alcantara sport steering wheel left from Superb. Might need to swap buttons from current steering wheel to sport one  due to this "View" Button .
8) And at last but not least will be chip-tuning. Still in the progress of selecting best map. Always have alternative to go to trusted old one  garage (where I did already 3 cars) but maybe its time to look at something new , like Powergate3 as example?
  • Replies 63
  • Views 38.4k
  • Eibach springs all around, front Koni FSD suspensions and 340mm front brakes are implemented.
  • ACC retrofitted as well.  No limiter , but who need it ?     (Airbag is not yet fully installed at that stage.)     (No speed limiter/mode selector)
  • Dietcokelight68
    Dietcokelight68
    Hi, you can change into Sportline/VRS so Red/carbon via VCDS coding.  STG17 > Anpassung > Kanal "Tuben Darstellung" > Change code  For the skin, ...... > Kanal "Displaydarstellun
And completely forgot about windows tinting :)
Will you do the coding yourself?
Looked on the VCSD (Ross Tech) forum yesterday regarding ACC - not a simple system as needs proprietry coding for the Radar - or swapping to an OLD style radar without the special radar module coding to your vehicle and some VCSD
What prices did you pay for the stalks and the VD?
Will be interesting to see how you get on - as I would like both of those mods too.
Same with the wheel arch trims - how much are they ... my dealer would not quote them nor the door trims on the scout (with silver accent).. said there was no prices in the system...
THANKS
Also - I do not use FB - so details of the supplier would be helpful.
10 hours ago, Gizmo said:
Where are they located?
Are they genuine and brand new?
They ship from Russia.  Took me  1.5 week to get my dashboard.
This is the only English language platform they are using. Another 2 are VK and DRIVE2.RU
THANKS
Nope , coding will be done remotely via team viewer with help of ODIS. VCDS is not good enough for this swaps.
I retrofitted ACC previously on my SUP3 and yes , this requare  so called "SWAP CODES" . Our radar is capable of being ACC radar , however you need to tell radar itself to became ACC plus Gateway needs to now how to work.  So this task technically require access to VW codes. Dashboard looks like a bit simpler , but still need remote access to VW databases as IMMO needs to be moved and keys readded.
10) Sound like I am going for front camera as well :)
Digital cockpit 90% retrofitted  (10% for missing Optical cable between head unit and dashboard require for maps to be displayed)
Impressive....
Have you done the parking sensors yet?  Would be interested to know how you removed the switch cluster below the AC controls.
For the coding... who did you get support from?
THANKS
8 hours ago, SimonAudi said:
Impressive....
THANKS
No , no parking sensors yet.  I found set , but too expensive. Will probably try to find serial number for wire loom and other parts ... or just save :)
For coding...  Seller did provide contact details with garage where the engineer will be able to do this remotely with help of the "team viewer" and ODIS I have.
On 18/04/2019 at 16:43, Shahoff said:
Hey man
Do you have the Button "VIEW" ? i have a phone instead of that. what do you h\ve?
58068389_382799275645173_861816170977479
Retrofitted borderless inside mirror. As I did this second time in my life its took me only 5 minutes of my lunch brake.
Had to purchase old shape airbag as my current one did not fit in to the Alcantara flat bottom steering wheel I had on my  Superb.  But found relatively cheap source and here it is:
Did you get the full display working after and resolve the Sat Nav com issue you were having?
All in what was your cost for doing the dash and ACC
THANKS
Yes , I just finished today  fibre cable install and coding to get full dashboard  functionality.
340mm front and Koni FSD
All together
On 18/04/2019 at 06:33, SimonAudi said:
Impressive....
THANKS
Got my parts for front parking sensors today. And a bit of plastic for front camera assist
Edited by Shahoff
6)  In some stupid reason I got Low end low resolution  RVC without trajectory 😞 Need to swap to High end one , but not quite sure if I need new wiring or not.  Maybe ( I hope ) just door handle with camera swap.
😎 And at last but not least will be chip-tuning. Still in the progress of selecting best map. Always have alternative to go to trusted old one  garage (where I did already 3 cars) but maybe its time to look at something new , like Powergate3 as example?
Amazing all, did you get all cables to connect Virtual cockpit? Was it too hard to connect all?
It can fit with Bolero infotainment or it needs other extras to have cockpit running?
