Front view camera
Hello
i already installed myself rearview camera (cheap one) , now i lowered my car and want to add also front view camera.
did anyone make it?
I just would need to k ow how to get trigger for video input on amundsen.
I think that for RVC bcm send trigger to radio to show video and searching how to manual send trigger to radio when its not in reverse? Any help would be great to male it possible
did you finally install it in some way?
Just found this topic,
As I can see, your solution would work only for not-OEM version of rear view camera, right? Because I can't see an option to connect to the box original camera, only the cheap from Aliexpress.
I know, that you can change it to OEM version with another unit for four cameras (area-view), but I was not able to found out version, which I will be able to fit in Octavia 3 mirrors and front grill. :D
Anyone achieve to make it work with MIB2?
  • 8 months later...
I dont think that this switch would work, becouse bcm detects reverse and send Can signal to radio to turn on camera, but when you ll push switch on that modul it will turn on the camera but wont be avle to seen on radio becouse BCM does not know and does not send Can signal to turn on screen for camera,.
I am not sure if i am right but i was thinking about that that it wont work, only if you would i stal some swith betwen bcm and reverse swith that you could turn it on when you have in 1 gear that will turn it on but also then the reverse lights would light...
Did anyone find any option?
  • 3 months later...
I am thinking to take the same approach but I think it requires a High Line reverse camera that can be activated from the button and just switch between the 2 cameras. My car only has a low line reverse camera and I believe that once I switch to first gear, even though I switch the camera to front, the radio will not display any video. I will still give it a try as I hope that once the radio has an video signal at input, maybe it will display it, but it's a long shot.
