Day Running LIghts Fault/Not Working
Hello everybody! :handshake:
Weird DRL fault; both sides. One moment working next time driving car, DRL not working... :sadsmile:
Checked fuses; all appear to be OK.
Replaced bulbs, with known working ones and also with brand-new bulbs.
Made sure DRL bulb holder fitted properly and tightly.
Bulbs in holder fairly snug fit.
Please help‼
Do you have a switch where the interior fuse panel is by your knees ?
If so then probably the switch is a fault, mine has failed and does the same symptoms, bumps in the road switch the lights of as the contacts in the switch have gone "weak"
New switch is around £18 or you could do what I have done temporarily and thats just join the wires together.
That's probably why Skoda removed the switch in the Fabia 2.5 Face lift :D
mines a facelift, still has switch tho (well not currently, its on order) 😂
No switch, as you have described, sorry! :sadsmile:
