Spark plugs changed still misfiring
1 hour ago, Mickmartin said:
Any pics of them fitted? Would be interesting to see.
Heres mine with all 4 fitted unlike others
as you can see cylinder 1 is a real tight squeeze due to the breather pipe, intake pipes and diverter valve but its all worth it for sure!
not even a tiny bit of misfire now whatsoever! Works like a dream with the denso spark plugs
  • Replies 89
  • Views 15.2k
  • UrbanPanzer
    UrbanPanzer
    Remove the tune / map, put it back to standard map and see if the problem goes away, if it does, the tune needs tweaking AND or other parts to fix the issue with the tune is required. Whoever mapped i
  • First thing i did this morning was call RTMG and got advised to check to fuses all, one fuse number 30 was blown, responsible for fuel pump, ignition, cruise control and the operation of PTC relay..
  • @Kobayashi Strangely after CAVE engines were getting Breather Mods & Software updates, and then Breather Mod 2 & Software Update, early CTHE that were Oil Users then got a Breather Mod an
Superb!
Are there any noticeable gaps where water could get into the plugs or are they completely sealed? It’s hard to see from the picture.
Does yours have the breather mod? or is that just a normal CTHE?
This is the CAVE breather pipe looks the same to me, CTHE / CAVE = Same breather pipe..
Edited by Kobayashi
11 hours ago, Mickmartin said:
Superb!
I cant notice any gaps as such but as they’re longer and wiggle freely my mind isnt completely at ease till i forcefully have to get that £125 bracket :(
Havent got a breather mod no
allow me to correct myself
Cylinder 1 was super difficult to install due to all the pipes highlighted below
one of them (main one which is pressing down on the coil pack in cylinder 1)  is from the oil tank, two click into the intake pipe and the giant diverter valve
6 hours ago, RezaVrs said:
I cant notice any gaps as such but as they’re longer and wiggle freely my mind isnt completely at ease till i forcefully have to get that £125 bracket 😞
The Audi 1.8T and 2.0T come with single cow ration adapters for each coil, I’d be looking to make my own somewhat like them.
The 'Breather mod' as i understand it is the pipe highlighted in blue off your own photo (this was not on my CAVE originally) and appeared after the oil fixes.
The breather mod must be standard on a CTHE.
Isnt the blue circled pipe the same as the one you circled here? This is a cave engine right?
Wouldn’t these push fit adapters help keep the coils firm?
yes mine is a CAVE so therefore you have the breather pipe as standard on your CTHE
Edited by Kobayashi
@Kobayashi
Strangely after CAVE engines were getting Breather Mods & Software updates, and then Breather Mod 2 & Software Update, early CTHE that were Oil Users then got a Breather Mod and Software Update.
That one surprised even me.
@MilgeS had the CAVE ownership experience, then bought one of the first  CTHE car & ended up needing a 2nd engine for that.
Edited by Skoffski
This would be interesting to know!
they’re £9 something from AwesomeGTI has anyone done this before?
On 05/06/2019 at 08:11, Mickmartin said:
I was on about the original Audi r8 coils not the copy's.
We only need to browse this forum for 5 minutes and you'll see posts littered with plugs and coil issues, Having that problem eliminated and replaced with what should have been the original factory setup provides the piece of mind, reliability and spark these cars should have came with.
What bracket/holder did you purchase?
Yes thats true, but to suggest the factory standard ones arent reliable does not make sense, 40,000 miles and no issues for me, I suppose it depends on how long you believe they should last.
I would consider coil packs a "servicable" part, just like HT leads etc in the older days, the fact they are as cheap as they are shows they are not meant to last forever, electrical items in that engine bay will always suffer due to the extremes in the enviroment.
Plugs are a different issue, thats well documented indeed as well as skoda "updating" them.
Edited by UrbanPanzer
Re OEM Coils which can be fine for maybe 2 or 3 sets of spark plugs life times.
The OP had a replacement engine.
The engine replaced likely had a spark plug that was failing or failed,  spark plugs failing can reduce the life of an ignition coil.
So Skoda / VW approve a new 'Base Engine' it has new spark plugs and yet the original from the factory Ignition Coils get reused.  Maybe one that has been on that spark plug with the early demise.
So Ignition coil life and the history of the spark plugs needs given consideration.  What a same when £4,000 of engine change gets done and 3 good coils and one suspect get used.
