Fabia mk 1 front coil springs
I have just had my front coil springs replaced with kyb k-flex springs(broken spring)...now the car sits lower and seems quite bouncy!....apart from the genuine Skoda ones which would you suggest...car is fabia 1.9tdi estate.
Edited by ebenezer
I fitted four Kilen branded ones on mine and it's exactly the same as OEM. Seems odd that the KYB ones have made your car lower.
The only explanation I can think of is that you have fitted KYB springs for a VRS which is obviously lowered as standard, unless you have the KYB part number available it's hard to see how you can get to the bottom of this.
I looked at the part number on the boxes and it stated the springs were for the standard 1.9 diesel.
I doubt the vRS springs would lower a non vRS anyhow.
I assume everything is fitted up correctly?
I'm thinking of replacing my springs front and rear, now do i get one's from my tps trade account or aftermarket?
 ( 1.9tdi est 2005
Edited by Pwilliamf
I used to like the Swedish car parts springs as they do all their own work and GSF used to stock them, I can't remember the brand name tho!
For cheapness, if you are not too bothered, just buy a set of Sachs springs from ECP on one of their "better" deals?
Edit:- https://www.lesjoforsab.com/spring-company/lesjofors-sweden.asp           that is the Sweden based spring manufacturer.
Edited by rum4mo
I bought a pair of continental direct springs for the standard 1.9 TDI and found after fitting only one the car sat level and were the same on both sides.
Nice detail :thumbup: The only thing different I do is to crack the strut top nut while it's still on the car as it makes it slightly easier once the strut is off. A 21mm spark plug socket with a spanner used on the outer flats and an allen key down the centre works great for this.
