Is there an update to Infotainment System (5Q0035842A / H24) newer than 0241?
I know this has been asked has anyone got any update on this system I have. 2015 MK3 Fabia. Thank you
Steve.
  • Replies 184
  • Views 49.2k
  • @plastix3000 I sent you 0253 via PM
  • All check your PMs.   Answering @Entropyk questions: - is the update definitely improving the issue? No idea. - how safe would it be do update the system myself, should the retaile
  • Check your PM
Steve.
0138 is available if needed.
I'm having issues with storing the seat positions in memory. I'm not able to set any new seat positions.
I went through many topics on Briskoda and found out that updating the software will resolve the issue.
Fortunately, I'm also having the exact same hardware H24 but the part number is different. Can anyone please help me with the software update?
I hope this update is valid worldwide!
3 minutes ago, dpen14 said:
Welcome to the forum,
You need to hold down the menu button to enter the hidden menu, this contains the Software Train and the correct update flash button.
Odds are software version 0253 is available.
Thanks for the information.
I can see only one update which also seems to be pretty old.
IMG_3177.thumb.jpg.b59a835d0469c895688702012018beb2.jpgIMG_3179.thumb.jpg.a513b2804204955ff43f014a95cc219f.jpgIMG_3178.thumb.jpg.423166ee2001a445c61e15da833caabb.jpg
Where do I download 0241-2 from? Or do I have to only connect an empty pen drive and it will download through mobile net? Please guide.
@dpen14 The first picture shows your current installed Software Train MST2_EU_SK_ZR_P0241T
This is also the correct location for firmware update button
Available is MST2_EU_SK_ZR_P0253T
The second image is only showing you what update(s) that have been applied, and what version you have running in the system
The third image, you should update via SD Card, I don't think anyone has ever had success with USB.
Download is via a private message, and you copying the extracted files to an SD Card.
Apologies for replying to an older thread, but would anyone be able to send me a more up to date firmware for the below Bolero?
1630346833_Screenshot2022-11-15at20_27_31.thumb.png.b6e7d060e6a3ded27fda6182fc6a989b.png
Been having odd issues with CarPlay and was hoping that this may help.
Probably 0253, but you need to hold down menu/setup key to view software train and this is also the location for the firmware update button.
Thanks for your reply.
Below is the screen showing software train. The current available updates were 0241 and 0241-2.
Will PM you 0253 version
Could I be sent the 0253 update? Having issues with carplay and hoping an update will fix them.
Will PM you link to 0253 version
Ho all, does anyone have the update files?
Odds are you can update to 0253
But you should verify Software Train.
Press and hold down menu/setup button for about 10 seconds to enter menu and read this value.  It is also location for the firmware update button.
43 minutes ago, Adryn said:
I will PM you a link to 0253.
Hy I know for sure that it's an update for this but I don't know where to find it.Thank you!
Version 8755 via PM
Is it possible to update with this firmware a SEat Leon with;
Hardware: H24 and software: 0245 ???
Many thanks
Many thanks
Welcome,
Please verify the full Software Train, hold down your Menu/Setup button for 10 seconds to enter the engineering menu.
MST2_EU_SE_ZR_P0245T <-- Should be yours
MST2_EU_SE_ZR_P0253T <-- Available
Edited by varooom
On 24/12/2022 at 13:33, varooom said:
Welcome,
Hi varooom I did the upgrade to MSt2_EU_SE_ZR_P0346T and for the moment it seems to work ok..
Thanks!
Sergi
Thanks!
Sergi
MST2_EU_SE_ZR_P0369T
This is available if you are on the 03xx series of firmwares
I don't know the difference between 02XX and 03XX, but if it will work on the hw 024 5QA035824 I'd like to have it, thanks!!
S
Are you running 0346 or 0246?
Because you should not load 03xx onto 02xx version of firmware.
Ideally please verify if you made a mistake above in typing in value.
