I need Bolero Update :-)
Hi @pab567.
Would you have an update to my 2015 Octavia's software, please? Thank you very much in advance
  • Replies 1.2k
  • Views 231.1k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
PM
Hi, @pab567
Is there any updates for skoda superb 3 2018-12?
PM
Hi, @pab567
Wondering if you can help, Skoda Fabia MK3 2016? Are there any software updates for this version
PM
Hi... is there an software update?
I'm probably a bit slow to the game but I found a site called MIB Solution which has the updates on it (I can see it mentioned in this thread now after searching).  Under the Skoda_ZR folder it lists the updates and the highest MU Version is 480.  I currently have 0369 installed, would it be safe to update to 0480?  Not sure as the modified dates are a bit out of sync.
Think I've sussed it now!  I'm on 03 version of the firmware so can only use those with that number.
Edited by zom414
Hello @pab567,
Long time lurker, first post here!
Picked up our latest addition to the family - a 2016 Yeti SE L with a Bolero infotainment system and I'd like to update it to the latest and greatest.......do you have a SW update for the following:
Thanks in advance,
bikefright.
PM
Hello @pab567, would you, by any chance, have an update for my Fabia III (11/2018)?
Thank you very much in advance.
Fabia_III_2.jpg.thumb.jpg.9f7fb7919ff3587cbf36f6830080aa48.jpgFabia_III_1.thumb.jpg.ca7faa4f651db5aafeea07cfb7bc00d9.jpg
Please send me new firmware for Bolero, Kodiaq 2018. Thank you.
Lurking for a while and interested in doing an update as well:
Installed SW Train version:
MST2_EU_SK_ZR_P0241T
Installed SW MU version:
0241
Part number:
5Q0035842A
Software version:
H25.14.35_STD2Plus_EU
I do have a few questions about doing the update that I can't really seem to get answered when searching, even though i'm sure the answers will be around somewhere,
I am wondering, since i've been reading up on doing a FW update yourself, can you safely ignore the error code B201A that seems to always happen due to a version mismatch?
And if you have smartlink (with carplay and android auto) activated with a license, will it remain that way after you update? I figure it will but i'd rather be safe. I do want to update to see if it resolves a minor issue i have using AA as it randomly crashes every now and then.
Thanks in advance!
On 04/05/2020 at 16:48, pab567 said:
Hello I have bolero 2015 multimedia I can do update ?                                    IMG_20230924_181047.thumb.jpg.d15c17bc2f4f38f64d19a1026154d473.jpg
if anyone has an update can you share it with me?
*****@*****.tld     .thank 🙂
Thanks in advance!
There is no way to avoid SVM (Software Version Management) error and it can be cleared only with diagnostics using special procedure with checksum calculation.
If you have valid original licenses they will still be active.
All check your PM
55 minutes ago, pab567 said:
2 hours ago, musi said:
Good morning in my multimedia there is no smart link there is no Car Play I want to update and open Green Money everything is closed there because it is the very first version Green Money only opens in a higher version that's why I want to make an update about the error or I will try to cancel it or I will leave it like that no  It really bothers me thanks
Your unit does NOT and will NOT support it, you must have both glove box and siplay unit replaced. If you are interested pls contact me on PM.
All check your PM
Understood, but the error doesn't interfere with anything when it comes to using the infotainment system from what i've managed to find, that's correct?
I didn't get a PM yet, I think it's version 253 I need based on what i can find and what i posted
Correct. PM resent.
Hi folks, just wondering if there's an update for this unit. Bolero in Octavia III 2013. Other details are included in the pic.
Hi, is there an update for this boler? Thanks in advance.
MST2_EU_SK_ZR_PO245T
0245
500035840A
H25.14.78_STD2Plus_EU
Hello!
Can't find the update😔
My current device:
System information
Device part number: 5Q0035840A
Hardware: H24
Software: 0245
Media Codec:
2101.0.0.10
Please help 🙏
Octavia III (2016)
Hello
 an anyone please share a link to download the latest firmware for bolero in a soda superb 4x4 year 2021
im at version 0306
thanks
