Airbag light and crash sensor
Hi it's me again .... I have an airbag light on .... diagnostics is saying crash sensor drivers door .......I'm sure I have seen somewhere that it is in a ridiculous place to get to within the door that has to be drilled out??? Thx
They are on the back of the window regulator panel inside the door. However the issue could be broken wiring inside the rubber bellows inside the door shut.
Edited by Tech1e
Yes agreed I must have a look in there before the car goes to a mechanic .....how do you get into those wires by the door hinge? Thx
Ok update on this, I checked the wires in the rubber by the door hinge and found a yellow airbag wire broken, I have temporarily put a connector on..... airbag light is still on though so I’m guessing this needs the fault clearing ADD93D5B-E473-43DB-98E3-59AEA9BED9C3.thumb.jpeg.5de3318861699a4ef5cddff7dcf2d041.jpeg
Yes, the fault code will need clearing.
