Climatronic Problem
Hello everyone. As the title says I'm having a problem with my climatronic. What actually happens is weird and I can't find a way to reproduce the problem myself. So when I'm using the climatronic on cold it works fine at the beggining. When I'm on the highway using the cruise control at 120 Km/h after some time it stops blowing cold air for about 2-3 min (sometimes even for 5 min). Then it comes back again blowing normally cold air. This will happen again at random moments and there's not a standard interval the problem occurs. This will not happen when I'm driving in town at lower speeds. I went to the dealer trying to explain the problem and they said to me there was a TPI and made an update to the ECU. When I got the car from the dealer and went to the highway the problem appeared again (at random intervals it was not blowing cold air). I bought a carista adapter and showed these 2 errors on the pictured attached. If anyone knows anything about this problem I would be glad for any help.
Thanks in advance.
Edited by Malediktion
