2011 Skoda Fabia 1.6 tdi DPF issues, electric windows etc., lessons learned!
Great info, thanks!
How hard was it to drop the subframe etc to get the exhaust out? I chickened out and cut the exhaust into three pieces, then bought a bolt-on flexi to join it back together again.
https://workshop-manuals.com/skoda/fabia-mk2/power_unit/1.6/55;_66;_77_kw_tdi_cr_engine/exhaust_system/removing_and_installing_parts_of_the_exhaust_system/removing_and_installing_pre-exhaust_pipe_with_diesel_particle_filter_vehicles_with_right-hand_drive/
https://workshop-manuals.com/skoda/fabia-mk2/chassis/front_suspension_drive_shafts/repairing_the_front_axle_on_vehicles_manufactured_up_to_cw_11_2008/release_the_assembly_carrier_and_align_in_the_service_position_(up_to_cw_11_2008)/
https://www.youtube.com/watch?v=JXrU-IuXSBo
at around 4:22 in the youtube video he scans the bolts to lower the subframe. Around 12 bolts to take out and it will drop down by about 10cm. Enough to get the DPF out as one assembly.
You arent taking the assembly fully out, just lowering it. All of the steering stuff stays connected. You will need a jack and some timbers to support its as its comes down. Its reasonably heavy.
The bolts should be replaced as they are called stretch bolts, and are meant to used once. (deisgned to fail in a head on  accident so that the engine goes under and not into the cabin)
Theres another youtube video out there from germany with a professional shop showing how to to do a complete DPF replacement, cant find it now, but had all the details on lowering the subframe, music with subtitles, somehing like the Autodoc videos. I think its was on a VW Golf, but it looked the same as the Fabia.
If i find it , i will post it here
Regards
T
Some other good info here....
https://www.myturbodiesel.com/wiki/diesel-particulate-filter-dpf-faq-repair-cleaning-and-pictures-tdi/
Very informative post. But a very brave effort on the DPF clean T Lee! I had the exact same issues and codes on mine (1.2 tdi) 2012 model. But mine appeared at 120k. I was lucky and used my VCDS system and iniated a service regeneration from the drop down menu using info from the net. My other half drove the vehicle while I kept an eye on the soot values and sequences from the display. Being done when we had the hot spell in the summer helped this as I was astonished how hot the engine and exhaust systems were getting!  Since then I have not had any issues with the DPF. I avoid supermarket diesel and occasionally put some additive (cata clean or forte DPF cleaner).  I also leave the vehicle to idle if it's in the middle of regen until the fan cuts down and the revs lower. I feel this stops interruption and the ecu can calculate what's needed to clear down on the next driving cycle. Yes I do give her a hammering just to keep the tubes clear every now and then but still no issues after 20k. Regens every 400 miles approx and takes about 7 minutes to complete 4 minutes if you give it some beans!
With regard to your door loom problems I had to replace both left and right door ones due to the electric windows stopped working. Also the alarm kept going off for no reason at sporodic hours in the night. I found 5 wires broken on the drivers door loom and 3 on the passenger side. Yes I agree bad design on where the door opens and closes. But the job changing them is very time consuming I could not  guarantee a solder / crimp repair by myself on the loom itself due to the possibility of any new breaks occurring after or before the repair. But it's individual choice.
Mine is approaching 140k which still has original battery, turbo, DPF and exhaust system. EGR changed at 90k due to some fault before this apparent 'fix' and oil cooler unit replaced due to coolant leak due to cracked water jacket casing plus cambelt and water pump at 130k. That's all.
Thanks A.
Have added some photos of cleaning the DPF in this thread:
https://www.briskoda.net/forums/topic/471100-replacing-mid-section-of-exhaust-16-tdi/
Regards
T
Re electric window wires, I repaired mine at the door hinge four years ago, no problems since - and I'll know where to look if it fails again.
