Skoda yeti 2013 Bluetooth and new iphone
Hello everyone, I'm new on here this is my first time posting please be kind.
I have had a skoda yeti TDI 2013 for a couple of year now and I absolutely love it, best car I've ever had. Anyway I recently got a new iPhone and the bluetooth connection between the phone and the car stopped working, the car still recognises there is some form of blue tooth there but won't connect, when I switch the blue tooth off on my phone the yeti is able to tell me the blue tooth has been disconnected. Its becoming a real pain without bluetooth connection now. I obliviously googled the problem which led me to the update portal. I was hopeful it said there are regular updates, but when I put the VIN in for my yeti is said there were none other than a radio station update.
Is anyone able to help
thanks Ramanda
Delete any unwanted Bluetooth pairings on the car and phone then restart the phone before trying to reconnect.
Ok many thanks I’ll try
Can you tell me how to do this please if it’s at all convenient
I suspect your phone is running a newer BT system which the car cannot connect to.
Yes 2010 yeti would not work with a 2013 phone, things move on
It’s a 2013 yeti and a new ish iPhone, is there anyway around this ?
thanks for your time
Thanks will try again
mine is a 2013 Yeti and my iPhone is a year old and they connect no problem
Two threads merged so replies may look out of order.
I’ve tried all the above suggestions and nothing. Works I’m supposing the IOS and Bluetooth on my iPhone XR does not
mirror with the amusden software. Suppose I’ll have to go to a dealer but not sure if it would be worth the outlay. Thanks everyone for being kind with a dumbo 🤩
I still suspect that your new phone is using a newer Bluetooth protocol than the car can support, and I doubt that a dealer can do anything about it.
Ok many thanks I did wonder that myself x
Perhaps Ramanda should ask Macworld why they make this statement:
Quote
It’s backwards compatible
The good news is, Bluetooth 5 hardware is fully backward compatible with prior versions of Bluetooth. Your Bluetooth 5 phone will have no problem at all working with all the Bluetooth headphones, speakers, fitness trackers, automobiles, and everything else out there.
https://www.macworld.com/article/3262664/bluetooth-5-faq-everything-you-need-to-know.html
Edited by muddyjim
text size
HI I HAVE A 2011 YETI 2.0 diesel with iPhone xr paired up no problem just delet the phone that's connected and restart  and a pin number will appear to pair your phone to raido
