Side window driver door sealing strip problem - Felicia 5dr HB
I have problems with the sealing strip to the side window of the driver's door is unstable and causes the window to slip in the molding and there is a lot of wind noise from there. Is this something common error on the lists or?
When you wash the car with high pressure, you get full of water into the car and on the inside window.
Is the list to buy new still?
Step 1: goto 7zap.com.
Click CATALOGS icon. Click SKODA logo. Click FELICIA icon. Select Model Year and Engine from the left. Confirm selection. Select Body. From the left you choose the interest area. In your case I would look for "door, front" and "window lifter, guide channels, window slot seal for door, front". Select item number on illustration. Bam! Your part number.
Step 2: now you have the part number. Search on Google or contact a Skoda dealer.
Good luck!
If you mean "common defect" for Felicia, no, it is not.
I had the same problem in my trunk
i didn't searched for something original because it's easy here to find the similar from other brand.
The price is for meter,the guys which do such repairs tell the price for purchase and fitting.
No problem with rain etc,great job.
