Power loss
Evening all. Wonder if anybody has any pointers to problem that has appeared today please. 2014 Superb estate DSG 2.0 TDI.
I have lost power to the passenger side front and rear doors. This includes central locking, powered windows, and the doors are locked closed. They will not open using the internal pull handles.
Any ideas on cause please ?? (thinking possibly door loom ??). Any ideas on how to open the doors please, particularly the front ??
Regards, Paul
Have you tried engine on and using the door lock button on the passengers side front door by leaning over from drivers side to see if it will release the dead locks.
Will try thanks.
1 minute ago, Anglosaxon said:
Will try thanks.
That doesn't do anything...
Have also noticed (Now dark !!) that the illumination lights for the buttons and door handles are out as well
Have had suggestion possibly body control module.  Where would this be located please??
Would be worth a scan with vcds to see what the car thinks the issue is
Hi,
Both passenger doors are controlled by a module inside front passenger door.
It that module fails , both door won't work.
It's a known issue with the front doors cable loom that will fail / splice the cables which in turn make the modules work with interruptions .
Very likely to be a damaged driver's door wiring loom. Pull back the bellows between the door and the frame and inspect the wiring in there for cracks/breaks.
I've had similar failures due to snapped wires between the drivers door and A-Pillar. Soldered everything back together with slight cable extensions to ease the stress.
Everything has worked faultless since.
Many thanks for replies.  Update is, after suggestions, driver door loom replaced. This has not worked.
Any idea how to open passenger door as locked shut and won't even open using internal handle so cannot get to the wiring between door and pillar
