Warning lights - battery, washers
AlanJD
Recommended Posts
Warning lights are coming on but seem sensitive to bumpy roads so maybe a bad connection somewhere.  In detail
Battery light comes on and stays on when the engine is not running.  OK
Light goes out when engine started and idling.  OK
Light stays out when running during the daytime.  OK
Battery light and washer fluid lights come on at night when the headlights are on.  (But obviously there's no washer fluid sensor so light is spurious.)  Not OK.
Any suggestions where to start looking?
Link to comment
Share on other sites
Try the battery terminals and alternator connections first, maybe battery earth terminal
is one slightly loose if problem starts on bumpy roads
Link to comment
22 hours ago, KenONeill said:
How about when the HRW is on?
The HRW doesn't affect the warning lights.  (But a good suggestion.)
I'm giving advice at a distance so the car isn't currently in my driveway.  I think the warning lights (headlights, battery) are close (adjacent?) on the display.  Is it feasible that there's some bad internal contact which allows the power to the headlight warning light to also reach other warning lights?
Link to comment
If there is a corroded circuit board etc then perhaps. The only way to know is to look, though. I would have thought a short would have worked both ways, though. If the headlights illuminate the battery light due to a cross, would not the battery light illuminate the headlight etc.
It might also be a wire chaffed somewhere along its route to the dashboard but unless you have interfered with things, unlikely.
Link to comment
That can be the next possibility, dry joint on dash pod or cabling not fully seated/plugged in.
Link to comment
  • 4 years later...
I know this is an older topic but I feel relevant.
our fabia mk2 1.6 tdi developed faint warning lights which were traction light and washer bottle warning. Also with ignition off when entering the car, the door open light also faintly illuminates the oil light and I think one other.
Any way after lots of bad words and wiggling things, battery check etc. I found a similar fault online of an Audi a3. Their solution was a dehumidifier!! So I warmed the car up, in went the dehumidifier and hey !!! All faint lights gone. So turns out it was damp bleeding current.
took maybe 2 hours for it to be fixed.
I hope this helps anyone else with this or similar problems.
all other things like this I found online never came back with their fix.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
