I having an issue that diesel get mixed in coolant tank.
I'm having an skoda 1.4 diesel 2009 model  i facing an issue it's uncommon. Basically oil get mix with coolant by oil cooler issue. But here diesel is mixed in coolant tank.
  • 3 years later...
Hi I am facing same issue how you solved it please guide me machanic has been failed.
Edited by ColinD
Spoiler
  1. Check this
What is the VIN?
Hi Mahesh
22 hours ago, skodafabia9000 said:
Hi I am facing same issue how you solved it please guide me my contact no (snip) machanic has been failed.
Please share your contact number
Welcome to the forum.
This is a terrible approach to take as you are pulling the wealth of knowledge from the forum and into the private domain, we are all here to help eachother so if you need help, do it through the forum in a well documented and descriptive thread to help all.
Not only that, there are many phishers looking for peoples details so I wouldnt recommend putting your phone number on the internet or giving one out to an absolute stranger.
Now if as you say the diesel and coolant are being mixed there are two things that I would be checking;
1. The heads go porous on these PD engines so it could be diesel and coolant are mixing through the head casting.
2. There are a lot of coolant and fuel lines on top of the engine and near the coolant bottle, they are all the exact same size and colour houses, make sure no one has mixed them up and connected a coolant line to the diesel return and a fuel line to the coolant tank.
Edited by ColinD
Removed number
Ok brother
