2017 L&K Octavia KESSY Problem
I'm currently locked out of my 2017 L&K Octavia. Car doesn't respond to the fob (new battery has been fitted and all 3 fobs tried). I know how to unlock the door manually, but when I open the door I'm guessing the alarm will make some noise. My question is: Can someone advise how I might turn the alarm off,  seeing-as the car doesn't have an ignition switch/key. Thanks, Tony
Once you enter the car you press the button with the keyfob and it should work, i remember that it was described for emergency situations in the manual.
